QoS configs VOIP
bryantsteve
I have IP phones on a satellite network and would like to try cRTP header compression however the network topology is a C2811 router FE interface connecting to the satellite modem.
As far as I can tell RTP header compression is only available on slower speed serial links.
Is there an option for a FE Interface?
John Blakley
I'm not sure on the 2800 series, but on the 3745 you can run:
int fa0/0
ip rtp header-compression
HTH,
John
HTH, John *** Please rate all useful posts ***
Thanks John I dont see that option on the 2800
c28(config-if)#ip rtp ?
priority Assign a priority queue for RTP streams
reserve Assign a reserved queue for RTP streams
