09-25-2009 01:24 PM - edited 03-04-2019 06:10 AM
Don't know if this is the right place for the QoS questions...
I just have general question. If I want to guarantee bandwidth for certain traffic which will appear on all the subinterface, can I limit it on the main interface by placing a policy-map on it?
For example I have f0/0 on a 2800Rtr and I have 3 subinterfaces f0/0.1, .2, .3.
ip access-list ex ACL_traffic
permit ip host x.x.x.x any
class-map CMAP_traffic
match access-group name ACL_traffic
policy-map PMAP_traffic
class CMAP_traffic
priority 1000
policy-map PMAP
class class-default
shape average 1500000
service-policy PMAP_traffic
int f0/0
service-policy output PMAP
I did try this and the policy-map did work on both f0/0 and subint f0/0.3. However how does it work if I put it on them? If I put it on f0/0, does it averagely allocate 1/3 of bandwidth to each subinterface if they all have matched traffic and does it allocate all bandwidth to f0/0.1 if there is only traffic on f0/0.1 but not other two subinterfaces? Thanks!
09-25-2009 03:52 PM
I'm not 100% positive, but believe if you set the policy on the main Ethernet interface, that has subinterfaces, it would apply to all traffic using the interface. To limit its shaping to a particular subinterface, you would use a hierarchical policy on the subinterface (as you noted you tried and worked) or you could define a policy on the main interface with multiple classes, one to match traffic per subinterface, and control the traffic there. (Again, not 100% certain what the policy will "see" on a main interface which has subinterfaces.)
09-25-2009 05:26 PM
If the traffic you want to protect can come from several subinterfaces, you should apply the service-policy on the main interface. In this case you don't need to shape as the the physical interface speed is used as the implicit shaper.
If you apply your configuration to the main interface, you will not be able to send more than 1.5M total. If you apply PMAP_traffic named service-policy on the main interface, you will be able to use all the interface Bw (100M) and protect the traffic matching CMAP class-map.
Your configuration (called HQOS) is good if you need to apply it on a subinterface because it's a virtual interface so there is no default shaper here.
Laurent.
09-26-2009 05:07 AM
to add to Laurent's nice comments
if you havt diffrent source/distination
per subinterface
letsay you have two remote sites each will be communicate with one o fhte subinterfaces
site1 10.1.1.0
site 20.1.1.0
access-list 110 per ip any 10.1.1.0 0.0.255
access-list 120 per ip any 20.1.1.0 0.0.255
class-map class1
match acess-group 110
class-map match-all class1-1
ip dscp ef
class-map class2
match acess-group 120
class-map class2-1
match dscp ef
policy-map p1
class1-1
priority 100
policy-map p2
class2-1
priority 100
policy-map main-p
class1
shape average 2000000
service-policy p1
class1
service-policy p2
then apply it to the main interface this way you will shape each subinterface to diffrent abmount of bandwith and inside each policy will hsubpolicy that clasify your traffic and give it diffrent treatment
(HQOS)
good lcuk
if helpful rate
