QoS configuration question
Hi all:  We have a simple WAN consisting of our main office and two brand offices connected via point-to-point T1s.  We have 2811's in each location.
Here is my problem.  I have an application (servers in our main office)  which is a bandwidth hog, but which I must garrantee bandwidth.  The application makes heavy use of MS SQL.  My first attempt at creating a QoS policy was to use the QoS wizard to create the policy and to add a new class for the application based on the source/destination IP address.  I gave this class 40% bandwith and an LLQ.  This where configured on all serial interfaces.  Code snipets are attached below.
The problem is that the default class is still taking the majority of bandwidth during times of 100% bandwidth usage.  I need traffic to and from the application server to have precidence over all other traffic so that it behaves as if no other traffic is present.  That is what I thought "priority" did???
Thanks for teh help, Chris.
class-map match-any SDM-Transactional-2
class-map match-any SDM-Transactional-1
class-map match-any SDM-Routing-2
class-map match-any SDM-Signaling-1
class-map match-any SDM-Signaling-2
class-map match-any SDM-Routing-1
class-map match-any SDM-Voice-1
class-map match-any SDM-Voice-2
class-map match-any SDM-Management-1
class-map match-any SDM-Management-2
class-map match-any NextGen-2
match access-group 102
class-map match-any NextGen-1
match access-group 101
policy-map SDM-QoS-Policy-2
class SDM-Voice-2
  set dscp ef
  priority percent 5
class SDM-Signaling-2
  set dscp cs3
  bandwidth percent 5
class SDM-Routing-2
  set dscp cs6
  bandwidth percent 5
class SDM-Management-2
  set dscp cs2
  bandwidth percent 5
class SDM-Transactional-2
  set dscp af21
  bandwidth percent 5
class NextGen-2
   priority percent 40
class class-default
  fair-queue
  random-detect
policy-map SDM-QoS-Policy-1
class SDM-Voice-1
  set dscp ef
  priority percent 5
class SDM-Signaling-1
  set dscp cs3
  bandwidth percent 5
class SDM-Routing-1
  set dscp cs6
  bandwidth percent 5
class SDM-Management-1
  set dscp cs2
  bandwidth percent 5
class SDM-Transactional-1
  set dscp af21
  bandwidth percent 5
class NextGen-1
   priority percent 40
class class-default
  fair-queue
  random-detect
interface Null0
no ip unreachables
interface FastEthernet0/0
description $ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$$ES_LAN$$ETH-LAN$$FW_INSIDE$
ip address 10.1.1.1 255.255.0.0
no ip redirects
no ip unreachables
ip directed-broadcast
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
duplex auto
speed auto
no mop enabled
interface Serial0/0/0
description $FW_INSIDE$
ip address 10.10.2.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
encapsulation ppp
ip route-cache flow
compress stac caim 0
service-module t1 clock source internal
service-module t1 timeslots 1-24
service-policy output SDM-QoS-Policy-1
interface Serial0/1/0
ip address 10.10.3.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
compress stac caim 1
service-policy output SDM-QoS-Policy-2
logging trap debugging
access-list 1 remark INSIDE_IF=FastEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 2 remark HTTP Access-class list
access-list 2 remark SDM_ACL Category=1
access-list 2 permit 10.1.0.0 0.0.255.255
access-list 2 permit 10.2.0.0 0.0.255.255
access-list 2 permit 10.3.0.0 0.0.255.255
access-list 2 permit 10.10.2.0 0.0.0.3
access-list 2 permit 10.10.3.0 0.0.0.3
access-list 2 deny   any
access-list 100 remark VTY Access-class list
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip 10.1.0.0 0.0.255.255 any
access-list 100 permit ip 10.2.0.0 0.0.255.255 any
access-list 100 permit ip 10.3.0.0 0.0.255.255 any
access-list 100 permit ip 10.10.2.0 0.0.0.3 any
access-list 100 permit ip 10.10.3.0 0.0.0.3 any
access-list 100 deny   ip any any
access-list 101 remark SDM_ACL Category=256
access-list 101 permit ip host 10.1.1.21 10.2.0.0 0.0.255.255
access-list 101 permit ip host 10.1.1.22 10.2.0.0 0.0.255.255
access-list 102 remark SDM_ACL Category=256
access-list 102 permit ip host 10.1.1.21 10.3.0.0 0.0.255.255
access-list 102 permit ip host 10.1.1.22 10.3.0.0 0.0.255.255
Re: QoS configuration question
As per my knowledge LLQ is queuing method. It’s a combination of Priority queuing and CBWFQ.
LLQ = 1 PQ + CBWFQ
Here you can get bandwidth guarantee, but there are some limitations, not all.(You cant allocate full bandwidth of link to all classes).
Cisco recommends that, In LLQ
Priority = 33 % , Other CBWFQ = 42 % (That means total 75% is maximum limit, which can be used for guarantee traffic).Other 25 % is for class default (other traffic).
I will suggest you to go for CBWFQ its better, In that also you can use 75 %. Allocate the bandwidth to your Next Gen applications till 70 % (make 2 class and allocate like 35 % for each class). Allocate in percent , it will easy, Then configure the remaining bandwidth for class default.
It will work...
Do rate, for helpful post...
Uttam
http://www.startnetworks.blogspot.com/
I have two interfaces, serial 0/0/0 and serial  0/1/0.  That is why I have the percentages at 40 percent each.
      Make 2 different Policy map -- CBFWQ . Don't use LLQ.Since in LLQ the the priority queue is by default policed. So its better you can configure two CBWFQ and apply on two different interface. Match your application Next gen and allocate the bandwidth 50%. Then at the time of congestion it will get min 50 % of link bandwidth and in normal period it can utilize available bandwidth.
Do rate helpful post...
Uttam
263
