Webcast-Catalyst9k
QOS/COS on a T1 to T3 connection
Hello.
I am needing some advice on how to setup the following.
I have in the field T1 connected to a MPLS network coming back to a T3. The T1s are conjested with Lotus Notes, Oracle and Voip traffic. The field routers are 2821 with Call Manager plus they have a 16-port 10/100 module within the router. In my configuration, I have applied CBWFQ for the traffic going out of the serial port. But I need to apply a service-policy for the input since we get killed with Notes and Oracle traffic. I really need help on this..
I did create a serivce-poicy for input but I got this error when appling the policy so I know I got it wrong.
SFRTR01(config-if)#service-policy input abs-traffic-in
CBWFQ : Can be enabled as an output feature only
One more question, Right now we are only using 9Meg of the 4Meg pipe at the corporate office but will I need to put a serivce-policy on this????
Config from field.
ip nbar port-map custom-02 tcp 7777
ip nbar port-map custom-01 tcp 8000
ip cef
class-map match-any voice-traffic
match protocol rtp
match protocol h323
match protocol skinny
class-map match-any web-outbound
match protocol http
class-map match-any business-traffic
match protocol notes
match protocol netbios
class-map match-any oracle-traffic
match protocol custom-02
match protocol custom-01
class-map match-any oracle-http-traffic
match protocol http url "*compass*"
match protocol http url "*abs2000*"
match protocol http url "*gems*"
match protocol http url "*livelink*"
policy-map abs-traffic-in
class voice-traffic
priority percent 10
class oracle-traffic
bandwidth percent 50
random-detect
class oracle-http-traffic
bandwidth percent 10
random-detect
class business-traffic
class web-outbound
policy-map abs-traffic-out
class voice-traffic
set ip precedence 2
priority percent 10
set ip precedence 2
random-detect
set ip precedence 2
random-detect
set ip precedence 0
class web-outbound
set ip precedence 0
interface Serial0/3/0
bandwidth 1544
ip address x.x.x.x 255.255.252
ip nbar protocol-discovery
service-module t1 timeslots 1-24
service-policy output abs-traffic-out
interface FastEthernet1/0
switchport mode trunk
switchport voice vlan 2
interface Vlan1
description ***Data Vlan***
ip address XXX
ip inspect Webfilter in
interface Vlan2
description ***Voice Vlan***
ip address xxx
router ospf 1
router-id 172.27.250.122
log-adjacency-changes
network x.x.x0 0.0.0.255 area 2
network x.x.x.120 0.0.0.3 area 0
Re: QOS/COS on a T1 to T3 connection
CBWFQ can be performed only on packets exiting the interface.
hieu
Gold
I assume your issue is traffic leaving the main site with the t3 going to the remote site.
As stated above you can only use most these options outbound. You can police the traffic inbound but it doesn't always help because the traffic already used to bandwidth to get to the site before it is dropped. The only reason it partially works is because of how TCP does packet retranmission.
The best options is talk to your provider and see what they can offer. Since you are running VoIP I hope you have at lease some committed or gold bandwidth.
You should be able to mark your packet to correspond to a quality of service model they provide. This will allow them to queue the packets on their routers as they are being sent on the t1 to your remote site. This also solve the problem of any to any traffic where you cannot determine from moment to moment where traffic is coming from. As long as its is consitantly marked the provider will give preference to the traffic you want.
Another not so good option is to shape the traffic as it leaves the main router on the t3. This will only work if there is little traffic between the hub sites.
What you basically do is build a shaper class for each site. You match destination ip to place the data in the correct class which you then shape to a t1. This in effect makes your t3 look like a group of channelized t1's. Withing each of these classes you can apply a quality of service to limit the traffic. This tends to be complex to maintain and gets almost impossible if you have redundant pathing to the remote sites. This may be your only option if your mpls network you bought is all best effort with no commitments
133
