06-25-2007 05:56 PM - edited 03-03-2019 05:36 PM
Dear All,
The significant different for QOS setting between 3550 & 3560, is it 3550 use WRR and 3560 use SRR?
Thank You,
06-25-2007 06:24 PM
The 3550 switch used WRR as the queuing method. The new switches i.e the 3560 and the 3750 use SRR as the queuing method.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/scg/swqos.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swqos.htm
HTH,
Narayan
06-25-2007 07:42 PM
Hi Narayan,
Thanks a lot for your help. :)
Best Regards,
