Community Member
qos fro incoming traffic
Hello dear guys
i want to mark incoming traffic from my specific router to mark with high proirity quese for outgoing purpose
any hint please
1 REPLY
Community Member
Re: qos fro incoming traffic
Hi fren
Use MQC (Modulur QoS Config CLI mode)
prepare acl's to match the traffic which will be used in Class-map
Create class map to match the traffic,
Create Policy map to mark the traffic
and finally apply the policy map to incoming interface in order to bring policy in effect.
I have created a sample for you consisting of 3 different marking patterns.
STEP 1:- Create ACL's for class-map.
ip access-list extended BULK
remark >> >> SB SWD BIG-FIX <<
permit tcp any eq 52311 any
remark >> Port 80 WWW <<
permit tcp any eq www any
ip access-list extended HIGH
remark >> Citrix Dialog <<
permit tcp any eq 1494 any
remark >> SB Dialog <<
permit tcp any range 4510 4513 any
remark >> SNA Enterprise Extender <<
permit udp any range 12000 12004 any
permit tcp any eq telnet any
permit tcp any any eq telnet
remark >> Fil.Alarm TAS-Link <<
permit tcp any range 53257 53263 any
remark >> -Redbox/AKT- <<
permit tcp any any eq 14804
remark >> ICMP <<
permit icmp any any echo
permit icmp any any echo-reply
ip access-list extended LLQ
remark >> PBX I-LAN <<
permit udp any eq 5004 any eq 5004
remark >> Cisco SLA <<
permit tcp any eq 5004 any eq 5004
remark >> Avistar Video Conferencing <<
permit udp any range 4200 4299 any range 4200 4299
STEP 2:- Creat Class-map to match the traffic
class-map match-all BULK
match access-group name BULK
class-map match-all HIGH
match access-group name HIGH
class-map match-all LLQ
match access-group name LLQ
STEP 3:- Create Policy-map to mark traffic.
policy-map MARK
class LLQ
set dscp ef
class BULK
set dscp default
class HIGH
set dscp cs4
STEP 4:- Apply policy-map on ingress interface.
interface xyz
service-policy input MARK
Hope this helps.........
151
