QoS Help Needed
Hossy_923
I have Ooma (VOIP) at home and I also run CrashPlan (online backup software).  Unfortunately, those two are not the best of friends.  If CrashPlan is running at full speed, my Ooma connection suffers greatly -- I can hear you, but y.u .an't h..r m..   I might as well just use my cell phone.
I am trying to figure out how I can setup QoS (or something/anything) to monitor for Ooma traffic (either traffic from an IP, to an IP, IP and port combination, or a mixture of those) and in response either completely drop or severely limit the traffic for CrashPlan.
I've tried setting up normal QoS to give priority to the Ooma traffic, but it hasn't changed my connection quality.
I have a Cisco 871W running 12.4(15)T3.
Any help is greatly appreciated!
class-map match-any SDM-Transactional-1
match  dscp af21
match  dscp af22
match  dscp af23
class-map match-any SDM-Signaling-1
match  dscp cs3
match  dscp af31
class-map match-any SDM-Routing-1
match  dscp cs6
class-map match-any SDM-Voice-1
match  dscp ef
match access-group 5
match access-group 150
class-map match-any SDM-Management-1
match  dscp cs2
policy-map SDM-QoS-Policy-1
class SDM-Voice-1
  priority percent 33
  set dscp ef
class SDM-Signaling-1
  bandwidth percent 5
class SDM-Routing-1
  bandwidth percent 5
class SDM-Management-1
  bandwidth percent 5
class SDM-Transactional-1
  bandwidth percent 5
class class-default
  fair-queue
  random-detect
interface FastEthernet4
description Connection to Internet$ETH-WAN$$FW_OUTSIDE$
ip dhcp client update dns server none
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting output-packets
ip nat outside
ip ips sdm_ips_rule in
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
service-policy output SDM-QoS-Policy-1
access-list 5 remark Access group for SDM-Voice-1
access-list 5 permit 172.16.0.16
access-list 150 remark Access group for SDM-Voice-1
access-list 150 permit ip any host 172.16.0.16
access-list 150 permit ip host 172.16.0.16 any
10 Replies 10
Joseph W. Doherty
Disclaimer
The      Author of this posting offers the information contained within this      posting without consideration and with the reader's understanding   that    there's no implied or expressed suitability or fitness for any    purpose.   Information provided is for informational purposes only  and   should not   be construed as rendering professional advice of any  kind.   Usage of  this  posting's information is solely at reader's own  risk.
Liability Disclaimer
In      no event shall Author be liable for any damages whatsoever    (including,   without limitation, damages for loss of use, data or    profit) arising  out  of the use or inability to use the posting's    information even if  Author  has been advised of the possibility of   such  damage.
Posting
What kind of connection is this?  What's the available (actual) outbound bandwidth?
Do you know any of the particulars for either/both your VoIP and backup traffic?
Hi Joseph, I'm using AT&T U-verse.  12Mbps down, 1.5Mbps up.  Fa4 is a 10Mbps connection to the AT&T U-verse gateway.
I don't have the particulars on the ports used by either, but it's easy enough to get them.  I can do that if you'd like, otherwise you can just use whatever and I can find/replace.
Disclaimer
Posting
Try for a first go:
policy-map CBWFQ
class-default
fair-queue
shape 1400000
service-policy output CBWFQ
It didn't like "shape 1400000"
Hossy_Router_871W(config-pmap-c)#shape 1400000
% Invalid input detected at '^' marker.
Hossy_Router_871W(config-pmap-c)#shape ?
  adaptive        Enable Traffic Shaping adaptation to BECN
  average         configure token bucket: CIR (bps) [Bc (bits) [Be (bits)]],
                  send out Bc only per interval
  fecn-adapt      Enable Traffic Shaping reflection of FECN as BECN
  fr-voice-adapt  Enable rate adjustment depending on voice presence
  max-buffers     Set Maximum Buffer Limit
  peak            configure token bucket: CIR (bps) [Bc (bits) [Be (bits)]],
                  send out Bc+Be per interval
The command is: shape average xxxxx
Hope this help
That didn't seem to make a difference.  Still very choppy audio.
are there any errors on the interface. choppy calls and bad quality etc can not only be caused due to congestion etc but latency , packet loss, errors in the interface etc.
Disclaimer
Posting
Okay there are at least 4 reasons why it didn't help.
  1. Shaping value is too high
  2. Need to reduce tx-ring-limit
  3. We need to further prioritize VoIP and/or deproritize your backup application
  4. There also inbound (transient) congestion
For #1 try:
Shape average 1000000 (if this works we can experiment by slowly/incrementally making it larger)
For #2 try:
tx-ring-limit 2
For #3 try:
class-map match VoIP
match ??? (here we need to identify your VoIP traffic)
class-map match Backup
match ??? (here we need to identify your backup traffic)
policy-map CBWFQ_Shape
class-default
shape average 1000000 (we can adjust value later)
service-policy CBWFQ
policy-map CBWFQ
class VoIP
priority percent 30
class Backup
bandwidth percent 1
class class-default
fair-queue
service-policy output CBWFQ_Shape
For #4:
Verify difficult to deal with or mitigate - hopefully something above cures your problem
Hi Joseph.  Thanks again for your replies.  I am going through and testing your options.  Unfortunately, I cannot currently reproduce the failure so any tests for success are impossible at the moment.  I will continue to try and update this thread as results become available.
Based on the reading I've done thus far, it seems that tx-ring-limit may do the trick, especially with my original QoS policy.
I will keep you updated and thanks again!
Just an update: I am still unable to reproduce the problem, so I don't know if it's resolved or I'm just lucky right now.
From my original configuration (using the SDM-QoS-Policy-1), I've only added the tx-ring-limit 2 setting to Fa4.  'show run' shows that two settings were added:
tx-ring-limit 2
tx-queue-limit 2
I will keep attempting to reproduce the problem, but hopefully this solved my issue.  I think I might remove these options at some point to verify the problem still exists and re-add them to confirm this is the actual fix.
