Webcast-Catalyst9k
QoS Help
Im trying to prioritise by allowing 70Kbps of bandwidth to a particular connection on a frame relay connectivity. This is what I did
step 1
Configure the following ACL:
access-list 100 permit tcp 10.x.x.0 0.0.0.255 host x.x.x.x eq www precedence critical
where 10.x.x.0 is the network address of the source network and x.x.x.x is the host IP of destination
Step 2
Configure the class-map to use ACL 100(above ACL in step 1) and configure policy-map to prioritise 70Kbps of bandwidth to the class-map:
class-map fmis-traffic
match access-group 100
policy-map fmis-policy
class fmis-traffic
priority 70
Step 3
This command is then applied on the serial interface (couldnt apply it on the sub-interface) to activate the above policy-map:
"service-policy output fmis-policy"
can someone check this out whether this is the right approach or not and if you think of something better please let me know.
Thank you
Re: QoS Help
The 3 step process is correct but since you are matching the traffic destined to the server with precdence as critical ,how are you marking the traffic as critical and how do u differentiate the traffic destined to the server as critical and non critical.
I feel you have got some application on that server which you want to access over the WAN.
Then i feel simple ACL matching the source network(ur local lan) and the destination server ip is enough to be precise u can use the TCP option to define the port as you have already done ..
regds
Silver
Re: QoS Help
The QoS config for a FR sub interface ( or for any logical interface) is different.This is a good link to get you started
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080110bc6.html
Re: QoS Help
Thank you very much for all the information. I have done the following:
step 1
access-list 100 permit tcp 10.1.104.0 0.0.0.255 host 10.1.85.149 eq www
access-list 100 permit ip 10.1.104.0 0.0.0.255 host 10.1.85.149 precedence critical
Step 2
class fmis-traffic
priority 64
Step 3
This command is then applied on the sub-interface:
frame-relay interface-dlci 16
class fmis-policy
This config automatically appears:
map-class frame-relay fmis-policy
no frame-relay adaptive-shaping
Can you please advice me on this config and also how do I check that it is working. I just run the "show access-list" to see whether there is any match or any other command ?
Silver
Re: QoS Help
policy-map temp
class fmis-traffic
priority 64000
policy-map shape
class class-default
shape average 192000
service-policy temp
interface Serial2/0:0
no ip address
encapsulation frame-relay
load-interval 30
frame-relay lmi-type ansi
interface Serial2/0:0.598 point-to-point
description test connection
ip address 10.10.100.1 255.255.255.252
frame-relay interface-dlci 598
load-interval 30
map-class frame-relay shape
service-policy output shape
Under the frame-relay DLCI 598 apply the map-class
This should be the configuration. Pls apply this and check if it works
Re: QoS Help
Thank you attrgautam
Just a question on this. Why do I have to configure the "shape average 192000" on the second policy map ?. I have a frame relay with 128K Access and 64K PVC and I want the traffic to use the whole PVC-64K when there is traffic between 10.1.104.0/24 to 10.1.85.149 on port 80.
I have tried this and when I do a "show access-list" there is no match. I then apply this command to the serial interface(not sub interface):
"service-policy output fmis-policy" I didnt use "temp" but use "fmis-policy" as the name of the first policy map
Then I manage to see the ACL counters for the first ACL.Didnt see
Silver
Re: QoS Help
You will need to shape to 192K (or whatever is your link bandwidth) on logical interfaces(like sub interfaces/FR PVC/GRE Tunnels).
Apply the parent policy(not child policy) on the FR DLCI not main interface.
Re: QoS Help
Thank you very much. I have solve the problem using your solution. I was also having problem because of the old IOS version on the remote router which I beleive doesnt support QoS. That is the reason why I couldnt apply the "service policy output" command on the map-class.
Thank you once againa
138
