11-05-2011 04:56 AM - edited 03-04-2019 02:10 PM
HI All,
I am facing Voice Quality issue in Cisco Ip phone. However I don’t have any issue while calling between extension in the same Site. I am facing voice quality issue while traffic flowing through the MPLS over GRE tunnel. Its working fine If I am removing the mls Qos in Cisco 3550 Interface.
Core Switch 4006.
Access layer Switch 3550.
L3 between Core and Access layer Switch.
sh mls qos int fa0/12 statis
FastEthernet0/12
Ingress
dscp: incoming no_change classified policed dropped (in bytes)
46: 35393978 3387798 33358 0 0
0 : 2355401 2340850 14282944 0 0
Others: 1315189175 1173684911 159208693 0 0
Egress
46: 29636772 n/a n/a 0 0
0 : 24254784 n/a n/a 0 0
Others: 3608870199 n/a n/a 0 0
I removed the Qos on 4500 switches and mapped the cos 5 to queue 4 on 3550 but this did not fix the issue.
It was working fine and suddenly the voice quality issue happen.
11-06-2011 04:23 AM
hi,
can you post the config of the interface. Are you just enabling mls qos or are you actually trusting the markings from the phone as well. Is mls qos enabled globally on your switch?
Kishore
11-11-2011 08:12 AM
Hi Kishore
i enabled the mls Qos in Globally ,
mls qos map cos-dscp 0 8 16 26 32 46
mls qos min-reserve 5 170
mls qos min-reserve 6 10
mls qos min-reserve 7 65
mls qos min-reserve 8 26
mls qos
switchport access vlan 10
switchport mode access
switchport voice vlan 11
mls qos trust cos
wrr-queue bandwidth 20 1 80 1
wrr-queue min-reserve 1 5
wrr-queue min-reserve 2 6
wrr-queue min-reserve 3 7
wrr-queue min-reserve 4 8
wrr-queue cos-map 1 0 1 2
wrr-queue cos-map 3 3 4 6 7
wrr-queue cos-map 4 5
priority-queue out
spanning-tree portfast
If i am removing the mls qos in interface ., the Voice quality is Improved ...
Switch Model 3550
IOS : c3550-i5q3l2-mz.121-20.EA1
I have tried to Upgraded the IOS but no Luck ....
