12-08-2009 05:46 PM - edited 03-04-2019 06:55 AM
I have a 3825 with a 4 port etherswitch, and I was hoping to use one of those ports as the MPLS link in our HQ. However the etherswitch does not support outbound policies (Only inbound). Is there another module for the 3825 which does support outbound qos policies other then the T1 cards?
Solved! Go to Solution.
12-08-2009 07:49 PM
HWIC-1FE and HWIC-2FE inherits all features supported by onboard ethernet interface.These are routed ports whereas HWIC-ESW cards are layer2 ports.
HTH,
Nagendra
12-08-2009 07:49 PM
HTH,
Nagendra
12-08-2009 08:08 PM
Thanks!
