Community Member
QoS on Cisco 7304
Hi there, I'm currently try to configure QoS on a Cisco 7304 router with PA-A6-E3 interface card.
That 2 problems i'm encounter.
1. When i trying to enter the PRIORITY command under a sub-class inside a Policy Map i get the following error "priority not allowed in conjunction with bandwidth"
It's seem like i can't use the priority command after i has configured the bandwidth at some sub-class.
2. the fair-queue command is not availble when i try to configure at under the class class-default.
Appreciate your reply and thanks in advanced.
Cheers.
1 REPLY
Re: QoS on Cisco 7304
Hello.
1) That is correct. You cannot configure a priority bandwidth and a bandwidth under the same class. The priority class will always be served first but limited to the amount of bandwidth you give it. You must use one or the other.
2) Do you get an error when you try to configure it? Do you have anything else configured under class-default? The fair-queue command is only compatible with the 'queue-limit' or 'random-detect exponential-weighting-constant' commands under the same class.
Simon
460
