QoS on site-site vpns
ov
I have the following challenge:
My Cisco ASA5505, has two working site-site vpn tunnels. Over these tunnels (remote sites are also ASA5505), i want to run both data and voice traffic. I want to apply QoS on these vpn's, so that my voice traffic wont be affected by to much data going through.
I have looked at some simple QoS samples, but i'm a bit stuck, since this involves multiple vpns, not only one.
Any help is appreciated
Best regards
O.V
7 Replies 7
satish_zanjurne
Level 4
Level 4
Hi OV,
Below mentioned link should be able to give you some insight..
http://cisco.com/en/US/products/ps6120/products_configuration_example09186a008080dfa7.shtml
HTH..rate if helpful...
Marwan ALshawi
also this link contin details about bandwidth management in ASA:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008084de0c.shtml
Ok, i've looked at the links.
Is this a valid configuration? I dont have the ASA's here right now, so i cant test it:
class-map Voice
match dscp ef
match tunnel-group tunnel-grp1
match tunnel-group tunnel-grp2
policy-map Voicepolicy
class Voice
priority
service-policy Voicepolicy interface outside
Can i do a double tunnel-group match?
not practtical
becase this mean it should be the traffic from both tunnel-groups
while u need to match each one saparate
and make sure u have the voice marked correctly as EF in ur network
Ok, i need to match each tunnel-group separate, and apply the qos on the outside interface. How can i do this, when i can only apply one policy on the interface at a time?
You might be able to use the qos-group feature to mark each individual tunnel at the spokes, this way you could employ QOS at the hub based on these cos-groups.
Any chance of elaborating a bit on this?
