QOS over a WAN link
We are setting up faxing over our PTP link and someone has mentioned that we will need to give priority to this fax traffic, Can anyone tell me how I can accomplish this?
  • WAN Routing and Switching
Re: QOS over a WAN link
what you would need is priority queueing for your fax traffic. One way of accomplishing it would look like this:
ip cef
class-map match-all FAXtraffic
match protocol rtp
policy-map LLQ
class FAXtraffic
priority percent 20
class class-default
fair-queue
random-detect
interface Serial0
ip address ...
bandwidth 1024
service-policy output LLQ
You need to adjust your bandwidth statements and percentage values to suit your requirements. The "priority" command will ensure lowest delay, but be aware that a policer comes with it and you have to make sure to configure enough resources to support your FAX traffic.
The class-map could also be set up with an access-list. Just make sure your fax traffic is properly described.
For a full description of available commands and configuration examples have a look at "Cisco IOS Quality of Service Solutions Configuration Guide"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_book09186a0080435d50.html
and especially the parts 1 and 2. In general AutoQoS might be worth reading, because it simplifies the configuration.
Hope this helps! Please rate all posts.
Regards, Martin
148
