Webcast-Catalyst9k
QoS Question
I have three T1s configured in a PPP multilink bundle on a central router used by two additional site routers as an egress point. I now have a requirement to implement minimum access rates for each of the two remote sites with bursts permitted to utilize unused bandwidth. What type of QoS implementation would be best for this model? As a side note, I must classify traffic based on IP addresses because customer traffic is ecrypted and encapsulated at this point. Thanks.
1 ACCEPTED SOLUTION
Re: QoS Question
I would recommend to use CBWFQ (class-based weighted fair-queueing). This will give minimum bandwidth guarantees to a class with the allowance of utilizing the full available bandwidth. An example config would be:
class-map match-all Site1
match ip address 101
class-map match-all Site2
match ip address 102
policy-map OUT
class Site1
bandwidth percent 30
class Site2
class class-default
fair-queue
interface Multilink1
ip address 192.168.1.1 255.255.255.252
bandwidth 4500
service-policy output OUT
access-list 101 permit ip 10.1.0.0 0.0.255.255 any
access-list 102 permit ip 10.2.0.0 0.0.255.255 any
This assumes that site1 has IP addresses in 10.1.0.0/16 and gets at a minimum 30% of the link bandwidth. site2 gets also at least 30% and uses 10.2.0.0/16
Of course you would need to adjust IP addresses, interfaces and bandwidth parameters to your environment and needs.
Hope this helps! Please rate all posts.
Regards, Martin
Re: QoS Question
policy-map OUT
class Site1
class Site2
class class-default
fair-queue
bandwidth 4500
Regards, Martin
Re: QoS Question
Martin,
This is exactly what I was looking for. Thank you very much!
-Erik
104
