Community Member
QoS Service Policy Not Being Taken by GRE Tunnel Interface
I've created a nested QoS policy shaping traffic to 1 Gb/s on an interface forcing certain traffic to a priority of 66000 to use that pipe with the assumption that all other traffic will use best effort. I can see the commands pop up when typing them on a GRE tunnel interface but I get an error stating that the policy is not supported on input or output on the interface. Is that a license thing? Why can I type the commands but have the commands fail on a GRE tunnel interface? It is on a 6500 running sup72033-adventerprisek9_WAN-mz.122-18.SXF9.
Gold
Re: QoS Service Policy Not Being Taken by GRE Tunnel Interface
Did you try putting on the tunnel source interface or the tunnel itself ?
Community Member
I put the commands on the tunnel interface not the tunnel's source interface. The commands show up with a ? on the tunnel interface but fail so I assume it is reasonable to put it on the tunnel interface, until I got the error. Will the commands work on the tunnel's source interface if it won't work on the tunnnel interface itself?
Gold
try the source interface (It can't hurt).
I'm speculating here, but i suspect that
since the tunnel is a logical rather than phsical thats where the issue lies. Sorry about the double post
Gold
191
