You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Qos / shaping traffic and if required:
High-level topology design
1 Cisco 3560 48 port Layer  3 switch with the enhanced image at the main site.
The 3560 is used in a Layer 2 MPLS network and inter-network routing between VLANS.
A SVI is configured for the MPLS network and other internal networks.
One port g0/5 is configured on the MPLS Vlan that connects to the Ethernet link provided by the provider for MPLS connectivity via BGP.
The MPLS speed is 9 Mbps for the main site.
There are 100 remote sites that connect at 1.5 Mbps to the main central site at 9 Mbps.
Each site traffic is voice and minimal data.
The g0/5 is configured at 100 Mbps / Full duplex with the provider switch using a fiber to copper converter that connects to the 3560.
The interfaces are clean and no errors are present.
Should I configure traffic shaping on SVI so traffic does not leave or enter higher than 9 Mbps?
Can someone provide some examples if shaping is required on SVI for a 3560 switch and if it should be egress or ingress?
I believe all shaping options are egress but not 100% sure and not sure if they can be applied to a SVI.
Juan
  • WAN Routing and Switching
231
