Community Member
QOS traffic shaping
I am looking for some sort of validation or probably better recommendation for a traffic shaping design that we plan on implementing (service policy outbound) at the hub with dual Cisco7206 routers, each with 150M circuit facing to MPLS service provider.  The servers are mostly located at the hub and the traffic pattern is basically hub and spoke that talk to around 200 remote sites with various circuit speed from T1 to 20M.
The objective is for the hub not to send traffic to a site at a higher bandwidth that the site can handle.   I have defined that in the class-map and ACL for two sites but there will be more. My concern is for the remaining sites that are not explicitly defined.. they shouldn’t be shaped and should be able to use all available bandwidth of 150M.   In the sample configuration below, I used shape peak percent 100 statement for all remaining site but need more validation.
Thanks in Advance!
ip access-list extended ACL-Site1
permit ip any 165.179.171.0 0.0.0.127
permit ip any 10.146.1.0 0.0.0.255
ip access-list extended ACL-Site2
permit ip any 10.80.192.0 0.0.1.255
permit ip any 10.80.195.0 0.0.0.255
ip access-list extended ACL-Any
permit ip any any
class-map match-any Site1
match access-group name ACL-Site1
class-map match-all Site2
match access-group name ACL-Site2
class-map match-all Remaining_Sites
match access-group name ACL-Any
class-map match-any Class-EF
match ip dscp ef
class-map match-any Class-AF41
match ip dscp af41
class-map match-any Class-AF31
match ip dscp af31
class-map match-any Class-AF21
match ip dscp af21
class-map match-any Class-AF11
match ip dscp af11
class-map match-any Class-BE
match ip dscp default
policy-map vz-etm-Sub-Policy
class Class-EF
   priority percent 10
class Class-AF41
   bandwidth remaining percent 25
class Class-AF31
   bandwidth remaining percent 40
class Class-AF21
   bandwidth remaining percent 20
class Class-AF11
   bandwidth remaining percent 10
class Class-BE
policy-map vz-etm
class Site1
   shape average 6000000
   service-policy vz-etm-Sub-Policy
class Site2
   shape average 2000000
class Remaining_Sites
policy-map shape
class class-default
   shape average 141176000 564704 33664
interface GigabitEthernet0/1.871
bandwidth 150000
service-policy output shape
Everyone's tags (4)
446
