Webcast-Catalyst9k
QOS -- Unused bandwidth of priority class
Hello Expert
Our customer has a router which will be installed a 2M WAN link to connect another site. Because of the voice service will be implemented in local site, we are planning to implement QOS on the Wan link as below
50% bandwidth of WAN link for Voice (we say that it is priority class, priority command will be issued to the class)
30% bandwidth of WAN link for Data (we say that it is bandwidth class, bandwidth command will be issued to the class)
Other % of bandwidth put into default class
My question is, when the voice traffic only loaded 50% of prority class, Other classes whether can use the rest of % bandwidth of priority class?
Many Thanks
Re: QOS -- Unused bandwidth of priority class
The remaining bw not used by the priority class will be distributed among other classes as needed.
Cisco's definition of bandwith vs priority command: " Although the bandwidth guarantees provided by the bandwidth and priority commands have been described with words like "reserved" and "bandwidth to be set aside", neither command implements a true reservation. In other words, if a traffic class is not using its configured bandwidth, any unused bandwith is shared among other classes".
hieu
Bronze
hi
first 50 % + 30 % = 80 % is > 75 %, the ios will not let you go with this config remember you have a marge of 75 % of the configured bandwidth to play with the other 25% is reserved for system use unless you touch the max-reserved-bandwidth and cisco does recommand to change that 25 % of control protocol and system use or you use the percent command with priority or bandwidth in this case 50 % will be 50 % of 75 %....
the other question i m agree with what is posted .
do rate if it does help
597
