Webcast-Catalyst9k
QoS
Can someone pls describe,the difference between rate limiting,traffic shaping and traffic policing?
May be you can expalin based on a scenario in which a rate of 48 kbps is applied on a 64 kbps link..?
Also explain the formula in which the burst size is calculated..
What is the significance of burst size..?
Thnaks in advance,
Thomas.
1 REPLY
Purple
Re: QoS
Hi Thomas,
Rate-limiting is the same as policing. The following document explains the difference between policing and shaping quite well:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800bd8ed.html
Pls do remember to rate posts.
Paresh
115
