QoS
I was assigned a tasked to configure QoS on our backbone link to the internet to provide dedicated bandwidth to our special customers(i work at an ISP). I am thinking of using CAR, would this be the right option? e.g. 512kbps for each customer.
Re: QoS
Here is an example of a config I've used for an ISP before;
access-list 101 permit 192.168.1.1 0.0.0.0
class-map match-all 512customer
match access-group 101
policy-map QoS
class 512customer
bandwidth 512
interface multilink1
service-policy output QoS
You have many options when it comes to QoS and really depends on your current infrastructure and complexity.
Re: QoS
In addition to Adam's post you can try using CAR for individual customers which can make the process simple wrt to the interface on which they are connected at your end.
In case of policy map you may need to allow the network blocks of respective customers and create a new policy whenever you plan to do so..
regds
Re: QoS
thanks for that sir, you got any examples on how to setup CAR for individual customer?
Re: QoS
Hi Jethro
You can refer this link for configuring up the same..
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tqos_r/qos_q1ht.htm#wp1080850
regds
111
