Query about static route
I have add static route for network 10.64.2.0 on router.
But this route is showing 7 times instead of 1 under show ip route static .
why it is getting so .
For reference find the attachment
  • WAN Routing and Switching
Hall of Fame Super Silver
Re: Query about static route
Hello Suryakant,
what router model is this ?
what IOS image ?
post a sh ver
Hope to help
Giuseppe
hi Giuseppe
Thanks for your quick reply.
Here is output of sh version.
Router#sh version
Cisco IOS Software, 3800 Software (C3825-ADVENTERPRISEK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 18:20 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 3 weeks, 2 days, 17 hours, 22 minutes
System returned to ROM by reload at 03:55:39 IST Sun Apr 5 2009
System restarted at 03:57:14 IST Sun Apr 5 2009
System image file is "flash:c3825-adventerprisek9-mz.124-9.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.2) with 225280K/36864K bytes of memory.
Processor board ID FHK1126F1PQ
2 Gigabit Ethernet interfaces
16 Serial interfaces
8 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
Hello Suryakant,
try to follow Edison's suggestion
do clear ip route *
then re-issue
sh ip route static
other suggestion:
what is the output of
sh ip route
this is just to understand if is a problem in the output of sh ip route static.
If you still see multiple entries for the same static route try to reload the router.
Hope to help
Giuseppe
Hall of Fame Super Bronze
That's not a normal behavior and most likely you've hit a bug. Your RIB seems to be corrupted so either
clear ip route * or reboot the router if possible.
HTH,
__
Edison.
111
