Question About IOS Ver for pppoe server
I have cisco 2811 router and want to configure it for pppoe server .I've tested most of them (IOS) . But did not support PPPOE protocol.
Which version should I use for it?
Thank you
Pedram Rabeti
1 ACCEPTED SOLUTION
Pedram,
The PPPoE server functionality should be available in all recent IOS versions for 2811, starting with 12.4. I can confirm that 12.4 and newer with Advanced IP Services feature set we're using in our labs supports PPPoE.
Check for these commands:
bba-group pppoe global
interface FastEthernet0/0
pppoe enable group global
If these commands are available then the PPPoE server functionality is available as well.
Best regards,
Peter
Pedram,
Best regards,
Peter
Thank you  for answer   Peter
Best regard
125
