Community Member
Question about PPPoE and DNS
I've got a Cisco1841-AdvansedSecurity (don't ask me what for) and PPPoE connection through Ethernet-DSL modem.
Before 1841 I've used IPcop-Linux Firewall. When PPPoE connection starts, Linux automatically recieved couple of DNS server from ISP, so I don't have to add it manually.
Is there a way to keep same thing in 1841, without "ip name-server bla.bla.bla.bla"?
Right now my config looks that way:
vpdn enable
vpdn-group 1
interface FastEthernet0/1
description WAN connection
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
keepalive 120 20
no cdp enable
ppp authentication chap callin
ppp chap hostname LOGIN
ppp chap password PASSWORD
ip route 0.0.0.0 0.0.0.0 Dialer1
Re: Question about PPPoE and DNS
AFAIK, this can't be done on a cisco router, "ip address negotiated" negotiate the IP address only.
Plus the "ip name-server" command doesn't need any frequent changes, its a one time configuration command, it shouldn't be a problem.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Silver
Try the "ppp ipcp dns request" command under the dialer interface so it will force the 1841 to request dns server IP during the ppp establishment.
Pls rate if helps.
Krisztian
Community Member
Hello, Krisztian!
I've added "ppp ipcp dns request accept" and "ppp ipcp predictive", now router resolves address without "ip name-server", so - this method WORKS! :-)
But I found 2 new questions:
1. DDNS tries to update HTTP address BEFORE router gets DNS through PPP IPCP. And I've not found any way to suspense DDNS update for a couple of seconds. Using workaround - added "ip host members.dyndns.org I.P.ADD.RESS"
2. How can I use DNS, obtained throug PPP IPCP, in DNS spoofing (DNS proxy) for my LAN clients, which uses router IP as DNS.
Thanks a lot, your first advice was very useful! :-)
Silver
Happy to help :)
Take look at this link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801a7605.html
Pls rate if helps,
Krisztian
Community Member
I've figured out that I don't have to use DNS spoofing, DNS server is enough :-)
506
