Community Member
question about ss7 voice gateway?
if VWIC-2MFT-E1 in 3845-V/k9 can do as voice gateway of ss7 .
i am not family of voice .
and i am eager for answer.
thank you for any help!
Silver
Re: question about ss7 voice gateway?
As far as I know, it is supported
Community Member
E1 doesn't necessarily use SS7 signalling, but it should be an option.
Further, check this link which suggests how many SS7 signalling links per card including the E1 cards, and indicates that you should be able to do SS7 on an E1.
http://www.cisco.com/en/US/products/hw/vcallcon/ps2152/products_data_sheet09186a0080113700.html
I'd post in the voip forum though.
according to wikipedia most modern E1's use SS7 though:
http://en.wikipedia.org/wiki/SS7
http://en.wikipedia.org/wiki/E-carrier
118
