Question for VWIC3-1MFT-T1/E1 capabilities
I am trying to receive some feedback before purchasing the hardware....
I have a remote location connected to my data LAN via an Ethernet Private Line. On both ends I have  2911 routers with 15.2 OS version. I would like to install a voice card (VWIC3-1MFT-T1/E1) in both routers and connect also the voice switches (ALCATEL 4400) over the same WAN interface (Ethernet Private Line) as the data connection in order the give up the additional leased E1 that I have currently for the PABX PRI inter-node link between the same locations. Alcatel is using the ABC-F proprietary protocol over the PRI connection. The Alcatel board used is PRA-2.
Is this going to work? Has anyone tried a similar configuration? Did you experienced any issues?
Sam
29
