Question on BGP and secondary IP's on physical interfaces
pipsadmin
HI,
i have a 3845 with a external interface for peering BGP with the carrier for network 216.24.238.0 which works right. This network is on a loopback because I'm doing NAT.
I also have a physical interface with IP 216.24.227.0 as primary and 216.24.228.0 as secondary.
Even with the router bgp statement with network 216.24.227.0 and 228.0, only the primary interface gets advertised. For some reason the secondary netblock 216.24.228.0 does not get propagated through BGP. This is my issue. I dont understand why the seconday IP is not getting advertised.
Is there a way around this?
20 Replies 20
srinivas_816
Can you provide the BGP configuration on the Router .
srini
Nelson
In addition to the configuration requested by Srini I believe that it would be helpful if you post the output of show ip protocol and show ip route from the router (if the ip route output is large at least post every line from the output that relates to these networks that you mention).
It will be important to see whether auto-summary is enabled or not, what masks are used in the interface and whether the BGP network statements specify any mask.
Rick
Rick
rsgamage1
Level 3
Level 3
What is your conclusion that the secondary network is not getting advertised, based on?
If you swap these networks(primary/secondary) do you see the same behavior? This would be a good thing to start off with, if you haven't done so already.
Then you could check for any filtering applied(outbound filtering at your end and inbound filtering by the peering partner).
Auto-summary behavior has changed across Cisco IOS software releases. Initially, auto-summary was enabled by default. However, with Cisco bug ID CSCdu81680 ( registered customers only) this behavior has changed. In the latest Cisco IOS, auto-summary is disabled by default. When auto-summary is enabled, it summarizes the locally originated BGP networks to their classfull boundaries. Auto-summary is enabled by default in BGP. When auto-summary is disabled, the routes introduced locally into the BGP table are not summarized to their classfull boundaries. When a subnet exists in the routing table and these three conditions are satisfied, then any subnet of that classfull network in the local routing table will prompt BGP to install the classfull network into the BGP table.
Classfull network statement for a network in the routing table
Classfull mask on that network statement
Auto-summary enabled
For example, if the subnet in the routing table is 75.75.75.0 mask 255.255.255.0, and you configure network 75.0.0.0 under the router bgp command, and auto-summary is enabled, BGP introduces the classfull network 75.0.0.0 mask 255.0.0.0 in the BGP table.
If these three conditions are not all met, then BGP does not install any entry in the BGP table unless there is an exact match in the local routing table.
Note: If the AS that performs BGP does not own the complete classfull network, Cisco recommends that you issue the no auto-summary command under router bgp in order to disable auto-summary.
router bgp ABCDE
no synchronization
bgp log-neighbor-changes
network 10.1.227.0 mask 255.255.255.0
network 10.1.228.0 mask 255.255.255.0
no auto-summary
or
router bgp ABCDE
no synchronization
network 10.1.227.0 mask 255.255.254.0
no auto-summary
Srinivas
Harold Ritter
Nelson,
Assuming the netmask for both the primary and the secondary interface ip addresses match the one configured on the bgp network statements (/24 by default for 216.24.227.0 and 228.0), both should be advertised in BGP.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
ok, lots of questions here, I'll respond as best I can.
I only want networks 216.24.227.0, 228.0 and 238.0 to be advertised on this router.
interface Loopback1
ip address 216.24.238.2 255.255.255.0
interface GigabitEthernet0/1
description BGP_TO_MCI_CAMPAIGNER
ip address 216.24.228.1 255.255.255.0 secondary
ip address 216.24.227.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
duplex auto
speed 100
media-type rj45
no cdp enable
no mop enabled
router bgp 17358
no synchronization
network 216.24.228.0
redistribute connected
redistribute static
neighbor 209.167.212.241 remote-as 701
neighbor 209.167.212.241 description MCI_link
neighbor 209.167.212.241 version 4
neighbor 209.167.212.241 soft-reconfiguration inbound
neighbor 209.167.212.241 distribute-list 199 in
neighbor 209.167.212.241 distribute-list 101 out
no auto-summary
Extended IP access list 101
10 permit ip host 216.24.227.0 host 255.255.255.0 (2 matches)
20 permit ip host 216.24.228.0 host 255.255.255.0 (2 matches)
30 permit ip host 216.24.238.0 host 255.255.255.0 (5 matches)
Extended IP access list 199
10 permit ip any any (4 matches)
Routing Protocol is "bgp 17358"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
IGP synchronization is disabled
Automatic route summarization is disabled
Redistributing: connected, static
Unicast Aggregate Generation:
Neighbor(s):
Address FiltIn FiltOut DistIn DistOut Weight RouteMap
209.167.212.241 199 101
Maximum path: 1
Routing Information Sources:
Gateway Distance Last Update
209.167.212.241 20 18w1d
Distance: external 20 internal 200 local 200
Hope that this can clear some resasoning behind the problem I have.
Thanks...
P.S.: In order to get traffic in for the 3 networks, I had to tell the carrier to staticlly route 227 and 228 to us.
This temporary fix works, although I would like everything in BGP.
Nelson
In your original post you indicated that the primary address was advertised but not the secondary. In this post you are indicating that both the primary and secondary had to be statically routed. Can you clarify this?
It might help us find the issue if you would post the output of show ip interface brief, of show ip route (can we verify that these routes are in the local routing table) and of show ip bgp (or if that is large then show ip bgp
for the three routes that you want to advertise.
Rick
Rick
I mean the secondary IP on the interface G0/1.
Gateway of last resort is 209.167.212.241 to network 0.0.0.0
C 220.220.220.0/24 is directly connected, Loopback2
C 216.24.238.0/24 is directly connected, Loopback1
209.167.212.0/29 is subnetted, 1 subnets
C 209.167.212.240 is directly connected, FastEthernet3/0
C 216.24.227.0/24 is directly connected, GigabitEthernet0/1
10.0.0.0/8 is variably subnetted, 13 subnets, 3 masks
S 10.10.8.0/22 [1/0] via 10.10.71.1
C 10.10.14.0/24 is directly connected, FastEthernet2/1
C 10.10.15.0/24 is directly connected, FastEthernet2/0
S 10.10.65.0/24 is directly connected, GigabitEthernet0/0
C 10.10.71.0/24 is directly connected, FastEthernet3/1
C 10.10.72.0/24 is directly connected, GigabitEthernet0/0
S 10.10.112.0/24 [1/0] via 10.10.72.101
S 10.10.113.0/24 [1/0] via 10.10.72.101
S 10.10.114.0/24 [1/0] via 10.10.72.101
S 10.10.115.0/24 [1/0] via 10.10.72.104
S 10.10.116.0/24 [1/0] via 10.10.72.104
S 10.10.117.0/24 [1/0] via 10.10.72.104
S 10.10.120.0/21 [1/0] via 10.10.72.105
11.0.0.0/24 is subnetted, 1 subnets
C 11.11.11.0 is directly connected, Loopback3
C 192.168.0.0/24 is directly connected, Loopback0
S 192.168.1.0/24 [1/0] via 10.10.71.1
S 192.168.237.0/24 [1/0] via 10.10.14.8
C 216.24.228.0/24 is directly connected, GigabitEthernet0/1
S* 0.0.0.0/0 [1/0] via 209.167.212.241
Interface IP-Address OK? Method Status Prot ocol
GigabitEthernet0/0 10.10.72.1 YES NVRAM up up
GigabitEthernet0/1 216.24.227.1 YES manual up up
FastEthernet0/0/0 unassigned YES unset administratively down down
FastEthernet0/0/1 unassigned YES unset administratively down down
FastEthernet0/0/2 unassigned YES unset administratively down down
FastEthernet0/0/3 unassigned YES unset administratively down down
Serial0/3/0 unassigned YES NVRAM administratively down down
FastEthernet2/0 10.10.15.6 YES NVRAM up up
FastEthernet2/1 10.10.14.2 YES NVRAM up up
FastEthernet3/0 209.167.212.243 YES NVRAM up up
FastEthernet3/1 10.10.71.2 YES NVRAM up up
IDS-Sensor4/0 11.11.11.11 YES TFTP up up
Vlan1 unassigned YES NVRAM administratively down down
Vlan10 216.24.239.1 YES NVRAM administratively down down
Vlan20 216.24.239.129 YES NVRAM administratively down down
Vlan65 10.10.65.1 YES NVRAM administratively down down
NVI0 unassigned NO unset up up
Loopback0 192.168.0.3 YES NVRAM up up
Loopback1 216.24.238.2 YES manual up up
Loopback2 220.220.220.220 YES NVRAM up up
Loopback3 11.11.11.11 YES NVRAM up up
BGP table version is 130, local router ID is 220.220.220.220
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
r> 0.0.0.0 209.167.212.241 0 0 701 i
*> 10.10.8.0/22 10.10.71.1 0 32768 ?
*> 10.10.14.0/24 0.0.0.0 0 32768 ?
*> 10.10.15.0/24 0.0.0.0 0 32768 ?
*> 10.10.65.0/24 0.0.0.0 0 32768 ?
*> 10.10.71.0/24 0.0.0.0 0 32768 ?
*> 10.10.72.0/24 0.0.0.0 0 32768 ?
*> 10.10.112.0/24 10.10.72.101 0 32768 ?
*> 10.10.113.0/24 10.10.72.101 0 32768 ?
*> 10.10.114.0/24 10.10.72.101 0 32768 ?
*> 10.10.115.0/24 10.10.72.104 0 32768 ?
*> 10.10.116.0/24 10.10.72.104 0 32768 ?
*> 10.10.117.0/24 10.10.72.104 0 32768 ?
*> 10.10.120.0/21 10.10.72.105 0 32768 ?
*> 11.11.11.0/24 0.0.0.0 0 32768 ?
*> 192.168.0.0 0.0.0.0 0 32768 ?
*> 192.168.1.0 10.10.71.1 0 32768 ?
*> 192.168.237.0 10.10.14.8 0 32768 ?
*> 209.167.212.240/29
0.0.0.0 0 32768 ?
*> 216.24.227.0 0.0.0.0 0 32768 i
*> 216.24.228.0 0.0.0.0 0 32768 i
*> 216.24.238.0 0.0.0.0 0 32768 i
*> 220.220.220.0 0.0.0.0 0 32768 ?
What about the carrier side? Are all your network announcements allowed?
yes, they have an ACL that allows 227,228 and 238
Nelson
Thank you for the additional information. The things that you have posted look to me like your BGP should be advertising all three routes. Especially when all three are in your local BGP table as shown:
It might be helpful if you would post the output of show ip bgp neighbor 209.167.212.241 advertised-route. I expect that it would show that all three routes are advertised. It is looking to me more like it is an issue on the neighbor side than on your side.
Rick
Rick
Shows the same, all 3 routes advertised....
This was not the case when I set this up late saturday night, hence the reason I asked the Peer to setup a static route.
Now, I'm affraid to have that static route removed, and traffic being affected....?!?
Yes, the Internet can not see your 227 and 228 networks being advertised via BGP by your AS, but 238 nework.
http://traceroute.org/#Route%20Servers
telnet://route-server.belwue.de
Therefore, it would be better to be cautious.
