01-20-2014 07:45 AM - edited 03-04-2019 10:07 PM
Hi Guys,
I have 2 simple questions about ODR. For example's sake, let's just say:
Spoke router---------------------Hub Router
I am running EIGRP on my hub router, and I have ODR enabled so my hub sends default route to my spokes.
Question 1: I know I have to redistribute the ODR routes into EIGRP in the hub, but do I also need to redistribute the EIGRP routes into the ODR instance? I believe I do, but I just want to confirm.
Question 2: Let's say I want to add a redundant router to the spoke and use HSRP. Will ODR still work as expected in a spoke environment using HSRP?
Solved! Go to Solution.
01-20-2014 09:28 AM
1) why would you redistribute EIGRP routes into ODR on the hub?
The spokes all have a default route going to the hub and the hub knows the EIGRP routes
2)I'll have to lab it up
Alain
01-20-2014 09:28 AM
Alain
01-20-2014 11:40 AM
Alain,
1. Yeah, that's what I figured. I haven't done much in the way of redistribution and didn't know if the two protocols had to redistribute into each other by design. Just wanted to double check.
2. Excellent reference, Thanks. Looks like it should work.
