Question on OSPF LSA Throttling and SPF Throttling
Hi Sir,
I wanted to configure the OSPF LSA Throttling and SPF Throttling features on the routers in a single OSPF area (Area 0). The commands are:
router ospf <process_id>
timers throttle spf ...
timers throttle lsa all ...
timers lsa arrival ...
Is it a requirement that the features be configured on all routers in the area? What's the overall implication if the above features are only configured on a few of the routers?
Please advise.
Thank you.
B.Rgds,
Lim TS
Purple
Re: Question on OSPF LSA Throttling and SPF Throttling
Lim,
The impact of doing this on a subset of routers would be that convergence time would only be as good as that of the slowest router (in terms of processing SPFs and LSAs). However, it will not break OSPF in any way.
Therefore, I recommend that you enable it on all the routers if possible.
Paresh
Bronze
Did you get this to work?
Was there any issues?
I also have multiple L3-switches and routers in Area0 and want to increase convergence. I want to add the following but not sure of the impact. Can I start adding this to each router and switch without worrying to much on the routing table?
Assuming a current stable network, I think these convergence changes will not drastically impact my production network while I make the changes.
ospf 1
ispf
timers throttle spf 10 100 5000
timers throttle lsa all 10 100 5000
timers lsaarrival
311
