question on VPN and vlan overlap on 2 remote sites.
ok, so I have 2 cisco 3845.
Site A's public 216.24.230.2
Site A's private 10.10.10.0/24
Site A's host 10.10.10.200
Site B's public 216.24.238.40
Site B's private 10.10.10.0/24
Site B's host 10.10.10.100
Both sites have the same internal IP schema.
How can I make a VPN between the 2 sites, so that host in site a has full access to host on site B.
As you can see, i'm very newbie when it comes to VPN's.
Thanks in advance.
Hall of Fame Super Blue
Re: question on VPN and vlan overlap on 2 remote sites.
Nelson
Start with this document and come back if you have further questions -
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800b07ed.shtml
Jon
but this is for same IP addresses on both sides... I don't have that issue. I simply want the VPN to pass traffic like if it was a bridge to the other site.
So that when I ping from site A to site B's host, it looks like it's local.
Is this at all possible?
is there a way to basicaly use the VPN to extend the broadcast domain to the other site? I dont have conflicting IP address, but I also cannot do NAT because of the applications being used and sone other dependencies...
Nelson
Apologies for misunderstanding, you made it sound like an overlapping subnet issue.
L2TPv3 will allow you to extend a vlan across a L3 routed link but i think this is more complicated than just using the example i previously supplied -
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
Jon
156
