Question related to OSPF process ID
Manish Prasad
Level 5
Level 5
Hello Netpros,
My question is related to the OSPF different process ids running on a single router.Do there is any method to synchronize two different OSPF ids advertised network to the neighbor routing table.
R1#sh ip ospf database
OSPF Router with ID (10.10.2.1) (Process ID 12)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
10.10.2.1 10.10.2.1 192 0x80000001 0x00548B 1
OSPF Router with ID (2.2.2.2) (Process ID 28)
1.1.1.1 1.1.1.1 1042 0x80000008 0x00E943 4
2.2.2.2 2.2.2.2 1559 0x80000004 0x0038F1 4
3.3.3.3 3.3.3.3 1525 0x80000003 0x00F82B 4
R1#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
9.0.0.0/32 is subnetted, 1 subnets
C 9.9.9.9 is directly connected, Loopback9
10.0.0.0/32 is subnetted, 6 subnets
O 10.10.2.2 [110/65] via 10.10.2.2, 00:48:18, Serial0/2
O 10.10.1.1 [110/65] via 10.10.0.1, 00:48:18, Serial0/0
O 10.10.0.1 [110/65] via 10.10.0.1, 00:48:18, Serial0/0
C 10.10.0.2 is directly connected, Loopback0
C 10.10.2.1 is directly connected, Loopback2
O 10.10.1.2 [110/65] via 10.10.2.2, 00:48:18, Serial0/2
R2#sh ip ospf database
OSPF Router with ID (10.10.2.2) (Process ID 12)
10.10.2.2 10.10.2.2 690 0x80000002 0x0020C0 1
OSPF Router with ID (3.3.3.3) (Process ID 28)
1.1.1.1 1.1.1.1 1103 0x80000008 0x00E943 4
2.2.2.2 2.2.2.2 1620 0x80000004 0x0038F1 4
3.3.3.3 3.3.3.3 1584 0x80000003 0x00F82B 4
R2#sh ip route
R2#sh ip route
8.0.0.0/32 is subnetted, 1 subnets
C 8.8.8.8 is directly connected, Loopback8
C 10.10.2.2 is directly connected, Loopback2
O 10.10.1.1 [110/65] via 10.10.1.1, 00:49:02, Serial0/1
O 10.10.0.1 [110/65] via 10.10.1.1, 00:49:02, Serial0/1
O 10.10.0.2 [110/65] via 10.10.2.1, 00:49:02, Serial0/2
O 10.10.2.1 [110/65] via 10.10.2.1, 00:49:02, Serial0/2
C 10.10.1.2 is directly connected, Loopback0
I know OSPF process id is used to identify the OSPF routing process and it kept different database table for each process.But just for a curiosity is this possible?
Prasad
6 Replies 6
Manish Prasad
Level 5
Level 5
For more clarification
R1#sh run | be ospf
router ospf 28
router-id 2.2.2.2
log-adjacency-changes
network 10.10.0.2 0.0.0.0 area 0
network 10.10.2.1 0.0.0.0 area 0
router ospf 12
network 9.9.9.9 0.0.0.0 area 0
R2#sh run | be ospf
router ospf 28
router-id 3.3.3.3
network 10.10.1.2 0.0.0.0 area 0
network 10.10.2.2 0.0.0.0 area 0
router ospf 12
network 8.8.8.8 0.0.0.0 area 0
ip http server
no ip http secure-server
control-plane
Prasad
Edison Ortiz
You can't synchronize them but you can redistribute between OSPF processes to have routes from each OSPF database distributed to their respective neighbors.
HTH,
__
Edison.
Thank You Edison.
Could you give me any example how to redistribute between OSPF processes.
One more question when i was trying to add one more OSPF process on a single router i get some messages , please can you explain this....
"*Mar 1 00:32:24.755: OSPF: Start redist-scanning
*Mar 1 00:32:24.755: OSPF: Scan the RIB for both redistribution and translation
*Mar 1 00:32:24.775: OSPF: End scanning, Elapsed time 20ms^Z"
Prasad
router ospf 28
router-id 2.2.2.2
redistribute ospf 12 subnets
router ospf 12
OSPF hello packets do not contains process id.
So when the hello packet is exchanged with matching all the required field then atleast the neighbor router will make a INIT state relationship with this router(Process id doesn't matter here).
If so then why the neighborhood relationship table is not showing the adjacency with the router id 10.10.2.2..
R1#sh ip ospf neighbor
Neighbor ID Pri State Dead Time Address Interface
3.3.3.3 0 FULL/ - 00:00:36 10.10.2.2 Serial0/2
1.1.1.1 0 FULL/ - 00:00:38 10.10.0.1 Serial0/0
Prasad
Prasad,
Each interface can only belong to one ospf process. So the neighbor relationship will be established one of the two process ids for a given interface.
show ip ospf interface tells you which process id owns the interface.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
