Questions
1)is DSL/T1/T3/E1/E3 are Layer 1? are the considered Leased Line?
Give a link that describe their Functionalitires
2)ususlay what is the link between CE and PE routers in order to run L3 MPLS VPN?
Re: Questions
T1/T3/E1/E3 can be considered as lease line but DSL can be considered as broadband.
http://en.wikipedia.org/wiki/Digital_Subscriber_Line   -- DSL Link
E1 Link:
E1 carries signals at 2 Mbps (32 channels at 64Kbps, with 2 channels reserved for signaling and controlling), versus the T1, which carries signals at 1.544 Mbps (24 channels at 64Kbps). E1 and T1 lines may be interconnected for international use.
T1 Link:
A dedicated phone connection supporting data rates of 1.544Mbits per second. A T-1 line actually consists of 24 individual channels each of which supports 64Kbits per second. Each 64Kbit/second channel can be configured to carry voice or data traffic. Most telephone companies allow you to buy just some of these individual channels, known as fractional T-1 access.
T-1 lines are a popular leased line option for businesses connecting to the internet and for ISP connecting to the Internet backbone.The Internet backbone itself consists of faster T-3 connections.
T-1 lines are sometimes referred to as DS1 lines.
T3 Link:
A dedicated phone connection supporting data rates of about 43 Mbps. A T-3 line actually consists of 672 individual channels, each of which supports 64 Kbps.T-3 lines are used mainly by Internet Service Providers (ISPs) connecting to the Internet backbone and for the backbone itself.
T-3 lines are sometimes referred to as DS3 lines.
Usually in L3 MPLS VPN, Ethernet link will be used.Either it may be fiber link or ethernet link
regards
karuppu
Re: Questions
Hi karuppu
Thanks for ur good info, regarding this:
do y have links that describe deployment scenario for MPLS VPN
Re: Questions
Something I have for ethernet.have a look of the below url
http://en.wikipedia.org/wiki/Metro_Ethernet
regards
karuppu
Re: Questions
Hi Freind
what about if the Link is Fiber?
Re: Questions
Usually if you are buying STM link(155Mbps) it will come with fiber link and used to call as POS Link(Power over Sonet).There will be seperate module to connect this link with either router or switch(cisco 6500 series)
for more about SONET/SDH Link , just go through the below link
http://en.wikipedia.org/wiki/Synchronous_optical_networking
Karuppu
Re: Questions
Sorry to chime in ..
Your L3 VPN will work over all the above Links.
Would recommend books like:-
MPLS Configuration on Cisco IOS by Lancy/Umesh
MPLS fundamentals
MPLS and VPN Architectures by Ivan Pepelnjak
You would get more than enough knowledge for deployment.
206
