"AND" and "OR" operations in a route-map
The single match statement creates “OR” condition. For “AND”, it requires two separate commands.
route-map L3andVZB-Down permit 10
match ip address L3-FE-IP
match ip address VZ-DS3
The above will show up as single line when you do show run but “AND” operation will be used for match.
sh run
match ip address L3-FE-IP VZ-DS3
So, in start up config, the route-map above will be listed as...
...even though it was entered with two separate match statements.
My question is, when router reloads, how will it determine that it is suppose to perform "AND" operation on the route-map?
Paresh.
Re: "AND" and "OR" operations in a route-map
Paresh,
Two matches of the same type create a OR condition. Two matches of different types create a AND condition.
So in your case, you can't have a AND condition if both matches are "ip address".
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thanks for your comment. Actually, Cisco as well as I implimented and verified that the router was performing AND. The router I have is in production and cannot be re-loaded. Cisco TAC should be working on behavior after reload.
Thanks again,
Paresh.
Paresh,
The normal behavior should definitely be a logical OR not a AND. Here is a simple example.
PE1#sh route-map
route-map test, permit, sequence 10
Match clauses:
ip address (access-lists): test1 test2
Set clauses:
Policy routing matches: 0 packets, 0 bytes
PE1#sh access-lists
Standard IP access list test1
permit 1.1.1.1 (1 match)
Standard IP access list test2
permit 2.2.2.2
PE1#sh runn | beg router bgp
router bgp 4
no synchronization
bgp log-neighbor-changes
neighbor 192.168.14.1 remote-as 1
neighbor 192.168.14.1 route-map test in
no auto-summary
ip access-list standard test1
permit 1.1.1.1
ip access-list standard test2
permit 2.2.2.2
route-map test permit 10
match ip address test1 test2
PE1#clear ip bgp * soft in
PE1#sh ip bgp
BGP table version is 2, local router ID is 4.4.4.4
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 1.1.1.1/32 192.168.14.1 0 0 1 i
PE1#
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hello Mr. Hitter,
You are correct. I stand corrected.
Thanks for your help with this,
Paresh.
128
