"ip nhrp map multicast dynamic" not working
benstrauss
Equipment: 871 router
IOS version: 12.4(22)T
Given the following mGRE VTI configuration:
interface Tunnel1
bandwidth 1544
ip address 192.168.99.1 255.255.255.0
no ip redirects
ip nhrp map 192.168.99.2 169.254.0.2
ip nhrp map multicast 169.254.0.2
ip nhrp nhs 192.168.99.2
ip nhrp network-id 1
delay 4000
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key 1234567890
tunnel checksum
The "ip nhrp map multicast dynamic" does not seem to perform as documented.
While additional dynamic unicast mappings are provided by the next-hop server, as is shown here:
SiteA#show ip nhrp brief
Target Via NBMA Mode Intfc Claimed
192.168.99.2/32 192.168.99.2 169.254.0.2 static Tu1 < >
192.168.99.3/32 192.168.99.3 169.254.0.26 dynamic Tu1 < >
192.168.99.4/32 192.168.99.4 169.254.0.34 dynamic Tu1 < >
...the expected corresponding dynamic multicast mappings are not created, as is shown here:
SiteA#show ip nhrp multicast
I/F NBMA address
Tunnel1 169.254.0.2 Flags: static
Consequently, multicast traffic, such as EIGRP cannot be passed to 192.168.99.3 or 192.168.99.4.
Any thoughts?
10 Replies 10
Giuseppe Larosa
Hello Ben,
this C871 is likely to be a spoke router.
the right command for a spoke is:
while ip nhrp map multicast dynamic is needed only on the hub side so I would suggest to remove it from the C871 and to try again.
For sure only one of the commands have to be used.
Hope to help
Giuseppe
I am experimenting with a variety of possible configurations, and I do, in fact, need to be able to send multicast traffic directly to 169.254.0.26 and 169.254.0.34.
I know precisely what my goal is and would like to be able to handle this in a scalable manner, avoiding the use of potentially dozens of individual "ip nhrp map multicast" statements in the future.
The point is that the statement does not seem to function as specified.
Hello Ben,
It is also possible that the platform and IOS combination doesn't support the command well.
see the following reference design guide for DMVPN
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/DMVPDG.html
If your objective is to send multicast traffic see the section IP multicast in the above document.
It provides a link to IPmc and sample configuration.
Hope to help
Giuseppe
That document actually gives the following example on page 2-30:
•Spoke router:
interface Tunnel0
description dmvpn tunnel
ip address 10.173.20.10 255.255.255.0
no ip redirects
ip mtu 1400
ip pim sparse-mode
ip nhrp authentication secret
ip nhrp map 10.173.20.1 192.168.201.1
ip nhrp map multicast 192.168.201.1
ip nhrp network-id 10203
ip nhrp nhs 10.173.20.1
load-interval 30
tunnel source GigabitEthernet0/0.201
tunnel key 123
tunnel protection ipsec profile dmvpn
...which, apart from the use of ipsec, is quite similar to my configuration. It does, in fact, include the "ip nhrp map multicast dynamic" statement.
Hello Ben,
yes I do agree.
This says that the two commands for ip nhrp map multicast can be used together.
so the only option left is that is not working well on your router.
Best Regards
Giuseppe
Correct.
I also tried it on a 2621 with IOS 12.3(26) and got the same results. (Although the "show ip nhrp multicast" command is not available under this IOS version I can clearly tell that multicast is not working unless I use individual static multicast mappings.)
So when does this command work, I wonder. Has anybody actually verified that it ever works?
Ben,
I have never seen "ip nhrp map multicast dynamic" used in a spoke configuration before. It definitely works on the hub, because that is how the hub knows where to send EIGRP and OSPF multicast hellos too. I assume in this scenario you are trying to build a fully meshed DMVPN? Where every spoke is a neighbor to every other spoke?
Yes, but upon further examination, it appears that this command does not do what the documentation claims, or at least implies.
Given that the use of a next-hop server introduces a weakness to a fullly-meshed network which otherwise wouldn't exist (vulnerability to failure of all specified next-hop servers), unless all spokes are specified as nhs's, I might just wind up biting the bullet and specifying mappings for each node on every other node. A bit unmanagable, but more robust.
smaxeh
I was having a similar problem with the "ip nhrp map multicast dynamic" statement not working correctly on the hub.  I had to remove the tunnel and re-add it for it to work correctly.  Wireshark was showing the packets egressing the hub as having a destination address of 224.0.0.5 for both the "black" (post-GRE) and "red" (pre-GRE) side of the packets.   All the spokes had the "correct" destination (tunnel destination NBMA) set with the multicast address on the "red" side (pre-GRE).
make new post and I will try help you in this issue.
