Community Member
"no ip split-horizons"
Without using sub interface, we can avoid situation such as split horizon issues hampering routing updates on a frame relay network by using "no ip split-horizons". Will this kind of configuration fix the problem the same as using sub interfaces? Is this not a good recommendation? Why?
1 REPLY
Re: "no ip split-horizons"
readthis link example you will have clear idea:http://www.mcmcse.com/cisco/guides/frame_relay_subinterfaces_and_split_horizon.shtml
rate this post if it helps
regards
Devang
98
