Rameshwar
I have Existing PVC of 1500kbps with WIC 1T card would like to add 1724kbps to this PVC will it be supported or I need to go for another WIC card
Re: Rameshwar
a T1 is 1,544 mbit ... if you dont want to oversubscribe you would need a E1 (2 mbit) interface (if possible in your country) or a T3 wich supports 43 mbit.
Re: Rameshwar
E1 is supported. what i want to understand is existing PVC 1500kb and additional PVC 1724kb can it be supported on WIC 1T E1 card in 3725 router and actual links are terminating on Passport on passports links trunk. bet router and passport we have v.35 connection
Re: Rameshwar
the point is you only have 1544 kbit/s physicially on your interface, you can't get 1724 kbit/s over this interface (and absolutley never 3200 kbit/s) ... it don't make sense to configure a pvc with that much bandwith on the T1 interface.
Re: Rameshwar
so I need to procure one more WIC 1T E1 card and configure another PVC of 1724kb
Re: Rameshwar
yes.
103
