rate limit is running here or not rate limit is running here or not rate li
dears,
i have my billing system (Centile) i put at Billing this command :
lcp:interface-config=rate-limit output access-group 101 1024000 1 6000 512000 conform-action transmit exceed-action drop
and i get the following:
Feb 19 06:23:11.270: VT[Vi7]:Added new AAA cloneblk, now cloning from vtemplate/AAA
*Feb 19 06:23:11.270: VT[Vi7]:Clone Vaccess from AAA (131 bytes)
*Feb 19 06:23:11.270: VT[Vi7]:ip tcp header-compression
*Feb 19 06:23:11.274: VT[Vi7]:rate-limit output access-group 101 1024000 1 6000 512000 conform-action transmit exceed-action drop
*Feb 19 06:23:11.274: VT[Vi7]:end
*Feb 19 06:23:11.274: VT[Vi7]:Applying config commands on process "VTEMPLATE Background Mgr" (135)
*Feb 19 06:23:11.274: VT[Vi7]:ip tcp header-compression
*Feb 19 06:23:11.278: VT:Messages from (un)cloning Vi7:
^ exceed-action drop
*Feb 19 06:19:48.990: VT:Messages from (un)cloning Vi15:
*Feb 19 06:19:49.002: AAA/ATTR(00013CD5): del attr: 63A5AA94 0 00000009 interface-config(153) 99 rate-limit output access-group 101 1024000 1 6000 512000 conform-action transmit e
*Feb 19 06:21:13.714: RADIUS: Cisco AVpair [1] 122 "lcp:interface-config=rate-limit output access-group 101 1024000 1 6000 512000 conform-action transmit exceed-action drop"
*Feb 19 06:21:13.714: RADIUS: Session-Timeout [27] 6 43200
*Feb 19 06:21:13.714: AAA/ATTR(00013CDE): free all lists: 0x63A5A9F0
*Feb 19 06:21:13.714: AAA/ATTR(00013CDE): del attr: 63A5AA08 0 00000002 Framed-Protocol(62) 4 PPP
*Feb 19 06:21:13.714: AAA/ATTR(00013CDE): del attr: 63A5AA1C 0 00000009 username(318) 17 moread@tarasol.jo
*Feb 19 06:21:13.714: AAA/ATTR(00013CDE): del attr: 63A5AA30 0 00000009 password(226) 4 34 39 30 38
*Feb 19 06:21:13.714: AAA/ATTR(00013CDE): new list: 0x63A5A9F0
*Feb 19 06:21:13.714: RADIUS(00013CDE): Received from id 1645/67
*Feb 19 06:21:13.714: AAA/ATTR(00013CDE): cursor init: 63E85BF8 63A5A9F0 none none
*Feb 19 06:21:13.714: AAA/ATTR(00000000): add attr: 63A5AA08 0 00000001 service-type(245) 4 Framed
*Feb 19 06:21:13.714: AAA/ATTR(00000000): add attr: 63A5AA1C 0 00000001 Framed-Protocol(62) 4 PPP
*Feb 19 06:21:13.714: AAA/ATTR(00000000): add attr: 63A5AA30 0 00000001 addr(5) 4 255.255.255.254
*Feb 19 06:21:13.714: AAA/ATTR(00000000): add attr: 63A5AA44 0 00000001 netmask(215) 4 255.255.255.255
*Feb 19 06:21:13.714: AAA/ATTR(00000000): add attr: 63A5AA58 0 00000001 routing(281) 4 FALSE
*Feb 19 06:21:13.714: AAA/ATTR(00000000): add attr: 63A5AA6C 0 00000001 Framed-MTU(63) 4 1500(5DC)
*Feb 19 06:21:13.714: AAA/ATTR(00000000): add attr: 63A5AA80 0 00000001 link-compression(192) 4 vj
*Feb 19 06:21:13.718: AAA/ATTR(00000000): add attr: 63A5AA94 0 00000009 interface-config(153) 99 rate-limit output access-group 101 1024000 1 6000 512000 conform-action transmit e
*Feb 19 06:21:13.718: AAA/ATTR(00000000): add attr: 63A5AAA8 0 00000001 timeout(303) 4 43200(A8C0)
i need to know if this command is running well and if not any help please?
BR.
1 REPLY
Silver
Re: rate limit is running here or not rate limit is running here
It may be memory related problem better you reload the device so all the memory will return
130
