Rate limit Physical interface GSR
t.tashiro
I would like to cap a physical GE interface to 100mbps whist running vlans through it on a GSR i.e.
interface GigabitEthernet0/0/6
no ip address
no ip directed-broadcast
rate-limit input 100032000 12504000 12504000 conform-action transmit exceed-action drop
rate-limit output 100032000 12504000 12504000 conform-action transmit exceed-action drop
no negotiation auto
interface GigabitEthernet0/0/6.2
encapsulation dot1Q 2
ip vrf forwarding test
ip address 10.1.1.5 255.255.255.252
no cdp enable
interface GigabitEthernet0/0/6.3
encapsulation dot1Q 3
ip vrf forwarding test2
ip address 10.1.1.1 255.255.255.252
no cdp enable
.................etc
However when I apply the rate-limit command on GE0/0/6, I don't see any drop in traffic. Actually I have set up a throughput test through GigabitEthernet0/0/6.2 running at 1Gbps which I can see through sh int GigabitEthernet0/0/6 which does not drop to 100Mbps once the rate-limit is added
I have also tried a vlan policy map with but get the same issue when applying to an interface
policy-map gig-out
class all-vlans
police 64000 4470 4470
policy-map parent-gig-out
class class-default
service-policy gig-out
class-map match-all all-vlans
match vlan 1-4095
(config)#int gigabitEthernet 0/0/6
(config-if)#service-policy output parent-gig-out
% 'match vlan/pseudowire' not supported in gig-out
The GSR cards are 12000-SIP-601 and SPA-10X1GE-V2
Is there a way to cap this aggregate interface?
Mark
Ok, I found this link which I think answer to our question:
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/aggvlan.html
From this link, the following configuration should be supported:
policy-map Child
class class-default
policy-map Parent
class all-vlans
service-policy child
match vlan 1-4095
Laurent.
6 Replies 6
Laurent Aubert
You don't need two levels of service-policy in your case. Try the following one:
policy-map gig-out
class class-default
police cir 100000000 conform-action transmit exceed-action drop
Laurent.
Hi Laurent
I tried what you suggested but I still don't see any drop in traffic. As you can see from the results I applied it bu the aggregate interface is stall taking 875Mbps of traffic
policy-map gig-in1
class class-default
police cir 104000 bc 4470 be 4470 conform-action transmit exceed-action drop
policy-map gig-out1
class class-default
interface GigabitEthernet0/0/7
no ip address
no negotiation auto
service-policy input gig-in1
service-policy output gig-out1
#sh policy-map interface GigabitEthernet0/0/7
Service-policy input: gig-in1 (240)
Class-map: class-default (match-any) (9166881/0)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: any (14941378)
police:
128000 bps, 4470 limit, 4470 extended limit
conformed 0 packets, 0 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps
Service-policy output: gig-out1 (242)
Class-map: class-default (match-any) (9191457/0)
0 packets, 0 bytes
Match: any (5027266)
Class of service queue: 14
Queue-limit: 32768 packets (default) Threshold drop 0 pkts, 0 bytes
Current queue-depth: 0 packets, Maximum queue-depth: 483 packets
Average queue-depth: 0.000 packets
police:
transmit
drop
sh interface GigabitEthernet0/0/7
GigabitEthernet0/0/7 is up, line protocol is up
Hardware is GigabitEthernet, address is 0021.1c59.e807 (bia 0021.1c59.e807)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec, rely 255/255, load 223/255
Keepalive set (10 sec)
Full Duplex, 1000Mbps, link type is force-up, media type is LX
output flow-control is on, input flow-control is on
Last input 00:00:04, output 00:00:04, output hang never
Last clearing of "show interface" counters 01:16:56
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
Available Bandwidth 1000000 kilobits/sec
5 minute input rate 875937000 bits/sec, 399611 packets/sec
5 minute output rate 876365000 bits/sec, 399808 packets/sec
381783166 packets input, 104608586928 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 113 ignored
0 watchdog, 0 multicast, 0 pause input
382965954 packets output, 104932671550 bytes, 0 underruns
Transmitted 0 broadcasts
0 lost carrier, 0 no carrier, 0 pause output
Laurent Aubert
I'm not a GSR expert but can you try the following configuration:
match vlan 1-4095
policy-map gig-out
class all-vlans
int gigabitEthernet 0/0/7
Laurent.
Hi, I've actually tried that as well however I see no drop in traffic :(
policy-map Child
class class-default
policy-map Parent
class all-vlans
match vlan 1-4095
Laurent.
Hi, that seems to have done the trick.
Mark
