07-08-2009 05:16 AM - edited 03-04-2019 05:21 AM
not able to find a traffic shaping utility that would rate limit a port of TCP protocol in a GRE infrastructure. GTS would be perfect, but it doesn't work in a GRE tunnel.
Any suggestions?
thanks, Kevin
07-08-2009 05:53 AM
Hello Kevin,
you should try to use Class based Shaping with modular QoS
see
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/reg_pkt_flow_shaping.html
Hope to help
Giuseppe
07-08-2009 09:27 AM
Giuseppe, excellent launch URL into QoS. My concern is, I think most traffic shaping QoS is applied on the out-going interface.
In my implementation, the remote site's WAN connection is an Ethernet ISP hand-off. This remote site is to be a "spoke" in a DMVPN infrastructure.
We're going to GRE "EIGRP" out to remote spokes as this one. So ultimately,
the question is "can you use traffic shaping in a DMVPN solution using GRE?"
