rate limited
I config a tunnel between HQ and remote office via Internet. The total Internet BW is 10M. I would like to allocate 2M for tunnel.
Do I apply the rate limited on tunnel? if so, it will limit the Internet traffic also. Any work around
rdgs
1 ACCEPTED SOLUTION
Re: rate limited
Hi Anita,
If you apply rate-limiting to the tunnel interface it will limit the traffic through that tunnel only.
The traffic that should go to the Internet will go directly through the physical interface and will not be rate-limited.
If you apply rate-limiting to the physical interface, then this will limit traffic to all directions: tunnel traffic and Internet traffic as well.
Cheers:
Istvan
1 REPLY
Re: rate limited
Hi Anita,
Cheers:
Istvan
91
