rate-limiting on Catalyst 3750
On catalyst I have one L3 (no switchport) interface, which is connected to ISP router (12Mbps rate-limit on ISP router).
On catalyst is configured some VLANs (cca 6) with public IPs. For example:
30.0.0.0/30 - ISP interface
30.0.0.1 - ISP default GW
30.0.0.2 - my catalyst
40.0.0.0/28 - red VLAN
40.0.0.16/28 - green VLAN
40.0.0.32/28 - blue VLAN
in each VLAN I have some servers.
And now, i need for example 5Mbps internet for red VLAN, 3Mbps internet for green VLAN and 4Mbps internet for blue VLAN.
5+4+3Mbps > 10Mbps = my aggregation :o)
how I can configure rate-limit for these VLANs?
rate-limit mustn't work on traffic between the VLANs
example:
RED VLAN to internet: 5Mbps
RED VLAN to BLUE VLAN: 100Mbps
thx for suggestions
Re: rate-limiting on Catalyst 3750
you could use shaped round robin queueing and assign each VLAN traffic to a separate queue on the ISP interface. SRR in shaped mode will give you an upper bandwidth limit. Be aware, that this can only be applied to output, so download rates can deviate strongly from the limits you would like to have.
Have a look at "SRR Shaping and Sharing"
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00805a6504.html#wp1200681
and at "Configuring SRR Shaped Weights on Egress Queues"
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_guide_chapter09186a00805a6504.html#wp1163879
for the technical details.
Hope this helps! Please rate all posts.
Regards, Martin
thx for suggestion, but i must limit both ingress and egress traffic.
my image: IP Base 12.2(25)SEE2
122
