rate limiting or policing or ...
Hi all,
This is v. embarrassing and urgent. Problem is - I think - easily solved, but not by me evidently :(
I need to prioritize the traffic from 1 network above that of another over a WAN link. It *must* be easy but I just don't know how to approach it so get too much info from Cisco website.
Backround: I've got a remote site with 2 vlans on a 3560 with IP Base. One port is configured as a rtr port for connection into a satellite service (just simple ethernet presentation and static routes)
One of these vlans must always take precedence over the other. At this stage I don't even need to worry about the type of traffic or anything.
Pls, pls help .. and thanks in advance,
mike
1 REPLY
Re: rate limiting or policing or ...
You can create 2 separate class-maps matching 1 network each. Then under policy map define the BW you want to assign to each network as per your requirement.
Refer this link for configuration help:
http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a00800949f2.shtml
Revert for any help.
hope that clarifies.
pls rate all helpful posts.
86
