11-24-2008 03:09 AM - edited 03-04-2019 12:28 AM
I am planning to do a complex migration from frame-relay to mpls and need to know what kind of traffic is traversing this link ?
What are my options or tools that I can do to accomplish this ?
Pls advice,
Cheers,
- InternetB -
11-24-2008 03:25 AM
11-24-2008 04:23 AM
Not as good as Narayan's suggestion using Netflow, but if the router supports NBAR, you might obtain an insight into the traffic crossing the router too.
11-24-2008 01:16 PM
Last, and probably least informative, you can use IP accounting. You would need to deduce application flows from source-destination IP pairs, which is a downside, but it can be applied quickly, and does not need additional devices, like a netflow collector.
- Thomas
