Read only access for Cisco Routers
dhilipsraj
I need a provide a read only access for a account in my cisco router. If I create a local account with priv 5, then when he does a "sh run" will he get all the details or details which are at priv 5 only???
cadet alain
He will only see the output related to the commands enabled in his privilege level not all show run.
Alain
Hi Cadet Alain,
Thank you for the response.
As follow up question, is there is a command that will be able to show which commands are  allowed to a specific privilege level?
Thank you.
if you have privilege level 15 and if the privileges were locally defined then sh run | i privilege will tell you.
if the privileges are configured on a TACACS server then there's no show command on the device but if a command is not enabled then when logged in with this privilege level the question mark will tell you what you can do.
Alain
