12-19-2005 02:55 PM - edited 03-03-2019 11:15 AM
Anyone know what this means ?
Am trying to do rfc1483 bridging over AAL5/snap encapsulated PVC but keep getting encapsulation failed.
rfc1483 routing works but wanted to do IRB to accomondate a small subnet.
12-20-2005 12:13 PM
can you post the configuration of your router ?
GP
12-20-2005 03:51 PM
It´s an Cisco 837 running c837-k9o3y6-mz.123-11.T5
version 12.3
no service pad
no aaa new-model
ip subnet-zero
ip routing
bridge irb
interface Ethernet0
no ip address
no ip route-cache
bridge-group 1
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
dsl enable-training-log
dsl lom 10
interface ATM0.1 point-to-point
ip address x.x.X.250 255.255.255.248
no ip route-cache
bridge-group 1
pvc 8/64
protocol ip x.x.98.249
encapsulation aal5snap
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
ip classless
ip http server
no ip http secure-server
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
line aux 0
line vty 0 4
end
12-20-2005 04:33 PM
It seems as if there are two separate issues that you need to fix:
1. You are unable to ping 157.157.98.249 - it gives you an encap error
2. You are receiving RFC-1577 compliant ARP packets
For your first issue, it's interesting that the debug output shows that the router is trying to route it via BVI1, which does not exist in your config. Did you have a BVI1 interface configured previously ?
To understand why you are getting the second error, we really need to look at the router at the other end of the PVC since that is the one sending it. It would appear that that router is configured for Classical IP over ATM. Could you pls post a config of that router ?
Paresh.
12-21-2005 08:03 AM
The config was probably some intermetiate config since I was doing a lot of testing, but I did test this with the BvI interface configured.
I don´t have access to the remote end of the PVC as it connects to a SP, sorry.
But anyway we solved this by put another subnet on the pvc and route the previous one over that one so the job is done
But I´m still a little cureous why I was not able to bridge this instead of routing it?
For instance I tried to debug the arp reply according to the RFC1577 but the content didn´t make sense to me which is probably why the error occurs.
0001 ar$hrd 16 bits Hardware type
0800 ar$pro 16 bits Protocol type
06 ar$shtl 8 bits Type & length of source ATM number (q)
04 ar$sstl 8 bits Type & length of source ATM subaddress (r)
0002 ar$op 16 bits Operation code (request, reply, or NAK)
00 ar$spln 8 bits Length of source protocol address (s)
03 ar$thtl 8 bits Type & length of target ATM number (x)
FE ar$tstl 8 bits Type & length of target ATM subaddress (y)
CC ar$tpln 8 bits Length of target protocol address (z)
9C54 9D9D 62F9 ar$sha qoctets source ATM number
0013 1A41 ar$ssa roctets source ATM subaddress
ar$spa soctets source protocol address
37C9 9D ar$tha xoctets target ATM number
9D 62FA ar$tsa yoctets target ATM subaddress
My mac-address is 0013.1A41.37C9
