Recommendation Central Ethernet Aggregation Router >30 Ports
i want to aggregate the following L3 Ethernet Fibrelinks in a central site. It´s planned to use BGP an Routing Protocol:
13 x 1 Gbit
10 x 100Mbit
  3 x 10 Mbit
7x 10 Mbit (Backup links, with only 2 Mbit bandwidth)
1-2 10Gbit
That central site will be connected over 2 fibres to two Routers at the main Datacentre. (At the moment, it is planned one 10G link as Primary and one 1G Link as Backup)
What would be your recommendation for this Setup? Would be a Catalyst 4507R a good starting point or would it be possible to use two stacked 3850?
Everyone's tags (3)
Hall of Fame Super Gold
I have deleted my 100% correct answer due to low rating unfairly received, and will refrain from further participating. Good luck.
Re:Recommendation Central Ethernet Aggregation Router >30 Ports
3750x, 3850, or 4500 will all work. Which one is best comes down to your budget and number of fiber ports / copper ports.
Mike
Sent from Cisco Technical Support Android App
274
