redirects
Sir,
I am trying to run this command
sh int description | redirect tftp:/192.168.1.1
but does seem to work ..
can somebody help?
regds,
aman
2 ACCEPTED SOLUTIONS
Re: redirects
One more thing. You should also specify the file name as follow:
tftp://192.168.1.1/
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222 Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Re: redirects
Sorry, I forgot the policy-list command under the kron occurence statement:
kron occurrence test at 7:30 recurring
policy-list test
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: redirects
try tftp://192.168.1.1 instead. Two slashes instead of one.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: redirects
tftp://192.168.1.1/
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: redirects
Sir,
thanks as lot ..
I have tried sh interfacde description | redirect tftp://10.192.10.57/isdn.txt & is working perfectly OK..
I had one more query can I create a batch file where in I enter secret password of router & capture show conf , show isdn active & show interface description etc..
Can u guide me on the same?
regds,
Aman
Re: redirects
Aman,
You can build TCL scripts on the router using the following feature:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00801a75a7.html
There is also a command scheduler feature available within IOS. It is similar to the kron scheduler available on most unix platform. For more information about the command scheduler, please refer to the following URL:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_feature_guide09186a00801b0695.html
You could also just specify a bunch of commands with the sceduler and not use a TCL script as follow:
kron policy-list test
cli show conf
cli show isdn active
cli show interface description
These commands would be run everyday at 7:30.
Let me know if that answer your question,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: redirects
policy-list test
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Cuauhtémoc, Juárez
México
Re: redirects
Sir,
Thanks ...
I have to go through this document & explore it ..
regds,
aman
111
