Webcast-Catalyst9k
Redistribute OSPF into BGP
Hi have a quick quesiton here I already have BGP/OSPF running on my router and it is redistrubiting OSPF routes already into BGP the problem. The issue is I have 2 more BGP peers on this router but they are not advertising routes. So I added:
redistribute ospf 1 match internal external 1 external 2 route-map to-SuntoV and I see the routes but the original BGP connection isn't adversting routes anymore. I found the hard way that when I added the above statement it over wrote my original with the new one.
So the original BGP connection stopped advertising routes. So question is how do I get this to work? The one in red is the new one that I'm trying to add
1 REPLY
Re: Redistribute OSPF into BGP
No worries I was able to fix it...I used route-maps to help advertise the routes.
Thank you
184
