05-25-2012 04:16 AM - edited 03-04-2019 04:28 PM
I got remote offices connected to our DataCenter some via MPLS and some via VPN terminated on Cisco ASA. I am running OSPF on LAN and BGP for MPLS sites. To have reachability to VPN remote offices I added 'redistribute static in OSPF' and to have rechability to sites connected via metro link i added 'redistribute connected'
router ospf 1
network 10.10.0.0 0.0.0.255.255 area 0
redistribute static
ip route 0.0.0.0 0.0.0.0 ASA
ip route 10.10.150.0 255.255.255.0 MPLS
ip route10.10.155.0 255.255.255.0 WAN_RTR
Ip route 10.10.157.0 255.255.255.0 ASA
ip route 192.168.12.0 255.255.255.0 ASA
Are there better ways of doing the config then above.
I also need restrictive access to Training Center i.e some remote office passing MPLS cloud can access Training Center site and some remote vpn office passing ASA can access Training Center site
ST
Solved! Go to Solution.
05-25-2012 05:11 AM
Hi ST,
You haven't said where your OSPF neighbors are, are the ASA, WAN router or MPLS routers OSPF neighbors, and are they under your control?
Assuming that your OSPF neighbors are connected only to your Core switch (and not shown in the diagram) I would do it this way:
router ospf 1
default-information originate
passive-interface default
no passive-interface
redistribute static subnets metric-type 1
ip route 10.10.157.0 255.255.255.0 ASA
Nick
05-25-2012 05:11 AM
Hi ST,
router ospf 1
Nick
05-25-2012 05:42 AM
Hi Nick
I got 15 offices in the same building of DataCenter some are uplinks and some are trunk ports, those sites are part of ospf
Looking at the above config not sure if I will be still able to restrict one remote office behind mpls to reach training_center site as per above topology
thanks
ST
05-25-2012 05:43 AM
you can restrict user access by using ACL's, prefix-lists etc..depends on how your configuration is setup etc. but in short , its doable
05-25-2012 05:46 AM
Kishore can you give example as per your post. my sample config you can view above in the post
05-25-2012 08:43 AM
Hi ST,
You just need a basic ACL on your Core Switch interface facing the MPLS router... e.g.
ip access-list extended ACL_MPLS_IN
deny ip 10.10.150.0 0.0.0.255 10.10.155.0 0.0.0.255
permit ip any any
int g0/0
ip access-group ACL_MPLS_IN in
This is just a very simple example - you can find more information here
Hope that helps,
Please rate any posts you find helpful.
Nick
