redistribute static
udayashankarsg
I had configured 3 eigrp autonomous systems in my router, but i have so many static routes. So, how do i configure the redistribute static that should learn only specific static routes in eigrp.
10 Replies 10
bjornarsb
Level 4
Level 4
Try this:
router eigrp 1
redistribute static metric 10000 100 255 1 1
network 172.16.0.0
metric 10000 100 255 1 1500
where 10000 = Bandwidth, 100 = Delay, 255 = Reliability, 1 = Loading, and 1500 = MTU.
You could also use a route-map if you need one:
redistribute static route-map XXX
Bjornarsb
HI Bjornarsb,
Can u reply the configuration for below example
I had advertised 172.25.7.0 on eigrp 110 but i have static routes for 172.25.4.0 and 172.25.3.0 and many other static routes. But i need to advertise 172.25.3.0 and 172.25.4.0 in eigrp autonomous system 110 using redistribute static route-map. So please help how do i need to configure ?
Hi Uday,
Give this a try
route-map permit 10
match ip address 1
access-list 1 permit 172.25.4.0 0.0.0.255
access-list 1 permit 172.25.3.0 0.0.0.255
Ankur
thanks. But i need one more information, Please help me. If i configure 3 automonous system. Example the network 172.25.7.0 in eigrp 50 and 172.27.3.0 and 172.27.4.0 in eigrp 110 and eigrp 120. But i need to advertise 172.25.7.0 in all the 3 autonomous system , how can i do this ?
Here you are:
router eigrp 1
redistribute static route-map static-to-eigrp
network 172.25.7.0
default-metric 10000 100 255 1 1500
ip route 172.25.4.0 255.255.255.0 XX
ip route 172.25.3.0 255.255.255.0 XX
access-list 1 permit 172.25.4.0 0.255.255.255
access-list 1 permit 172.25.3.0 0.255.255.255
route-map static-to-eigrp permit
match ip address 1
BR,
Bjornarsb
please reply to the above problem. How can i implement this ?
You can freely redistribute from any EIGRP process (using the process IDs or ASs) to another using route-maps as illustrated above.
Or since they are on the same router, just use the same network command "network 172.25.7.0" under the 3 EIGRP routing processes.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
I would like to give a litlle more less lines of command that you try with out the access-list.If you have many routes then it will surely help you to reduce no. of lines command.
Here you are:
router eigrp 1
network 172.25.7.0
ip route 172.25.4.0 255.255.255.0 tag 30
ip route 172.25.3.0 255.255.255.0 tag 30
match tag 30.
regards,
Like this:
(config-router)#redistribute eigrp ?
<1-65535> Autonomous system number
BR,
Bjornarsb
