Webcast- Automate Nexus9k
Highlighted
Community Member
Redistributing Of Routing Protocol
Hi Everyone
Can someone help to interprept the following
sh ip route 10.234.241.22
Routing entry for 10.234.241.16/28
Known via "connected", distance 0, metric 0 (connected, via interface)
Redistributing via eigrp 30, bgp 65037
Advertised by bgp 65037
Routing Descriptor Blocks:
* directly connected, via Vlan20
Route metric is 0, traffic share count is 1
May i know , wat does the Redistributing via eigrp 30, bgp 65037 mean ? Someone help to advice. THanks
4 ACCEPTED SOLUTIONS
Re: Redistributing Of Routing Protocol
HI, [Pls Rate if Helps]
The route 102.34.241.22 is Advertised to the network via parent "BGP 65037" Autonomous System.
This is redistributed into Eigrp 30 - Autonomous System.
Eg:
router bgp 65037
network 10.234.241.22
router eigrp 30
redistribute bgp
If you can post your configuration more we can still help more.
PLS Rate if Helps
Best Regards,
Guru Prasad R
Hall of Fame Super Gold
Alan
I agree that the output indicates that the subnet is advertised by BGP in AS 65037. I am not sure that it is redistributed into EIGRP and believe that there is a network statement for this network under EIGRP 30.
I agree that posting the config would allow us to to determine more exactly what it is. It would also be interesting and perhaps helpful if you post the output of show ip protocol.
Rick
Silver
Hi ,
*** Redistributing via eigrp 30, bgp 65037
10.234.241.16/28 is directly connected subent on the router and you are using eigrp and bgp on the router.
** Advertised by bgp 65037
subent 10.234.241.16/28 was advertised in BGP means it is redistibuted using "redisritbute connected" command under "router bgp 65037".
Satish
Alan
Thanks for posting the output of show ip protocol. In this output there is clear evidence that this subnet (or its interface) is included in EIGRP 30. In particular notice these lines:
Routing for Networks:
10.0.0.0
so there is a network statement for 10.0.0.0 and 10.234.241.22 is covered by the network statement and it is not made passive (only VLAN 30 is passive). So the address on VLAN 20 is an active EIGRP interface and the subnet is advertised by EIGRP.
It is harder to tell from the output about BGP. Pretty clearly BGP is advertising the network, but it is still ambiguous whether there is a BGP network statement for it or if it is being redistributed. I am thinking that there is a network statement for it under router bgp since it appears that BGP is redistributing static and eigrp routes, but that subnet is a connected subnet and not static or eigrp.
If you would post the config (or at least the router bgp part of the config) then we could determine for sure.
Rick
Eg:
router bgp 65037
router eigrp 30
redistribute bgp
PLS Rate if Helps
Best Regards,
Guru Prasad R
Alan
Rick
Community Member
The sh ip protocol config are as below, any can interprate. confusing on redistribution.
Routing Protocol is "eigrp 30"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 1
Default redistribution metric is 100000 10 255 1 1500
Redistributing: eigrp 30, bgp 65037
EIGRP NSF-aware route hold timer is 240s
EIGRP NSF disabled
NSF signal timer is 20s
NSF converge timer is 120s
Automatic network summarization is not in effect
Maximum path: 4
10.0.0.0
Passive Interface(s):
Vlan30
Routing Information Sources:
Gateway Distance Last Update
10.234.245.18 90 09:02:51
10.234.245.5 90 09:45:18
10.234.245.14 90 09:02:51
Distance: internal 90 external 170
Routing Protocol is "bgp 65037"
IGP synchronization is disabled
Automatic route summarization is disabled
Redistributing: static, eigrp 30
Neighbor(s):
Address FiltIn FiltOut DistIn DistOut Weight RouteMap
10.234.241.23 from-evpn
10.234.254.51
10.234.254.52
10.240.1.1
10.240.1.2
10.240.1.14
Maximum path: 2
10.234.241.23 20 01:50:41
10.234.254.52 200 09:34:59
10.234.254.51 200 09:05:29
10.240.0.22 200 32w2d
10.240.0.21 200 42w1d
10.240.1.14 200 01:50:42
10.240.1.2 200 09:05:25
10.240.1.1 200 09:05:40
Distance: external 20 internal 200 local 200
Alan
10.0.0.0
Rick
Community Member
Hi Rick
Thanks for your share of explaination to the config. I get what your explaination is about. It would be diffcult to post the config as the config that i posted is only a small part of a whole enterprise network.
Thanks again for the sharing.
Alan
Silver
Hi ,
Satish
158
